First of all, please excuse me if I did not post in the good forum section (1.37.20 version in docker but not dlandon image) or if this subject was already corrected (I made many search, made some modification found but still not work...).
I had good detection on dlandon/zoneminder.machine.learning image (1.36 version) but it was not using SHM on RAM, only disk so not good for resources.
So I decided to try gkirsteins/zoneminder.storage image and it is working well in RAM but events recorded do not show anything...
I have now 2 behaviours :
- Nothing to see on event recorded video and alarm frame.
- Nothing to see on event recorded video and we can see the cause of this event on alarm frame.
Do you have any idea of what could cause this issue? Do you need more informations?
Thanks in advance, best regards, Doudou.
Uncomprehensive motion detection
Re: Uncomprehensive motion detection
My case do not inspire you
What can I provide to help you to point the problem?
1.37.x are development versions.
If the 1.36 release version was working for you, I suggest you go back to that.
