bug: white page after save
lpadumorvan
Post by lpadumorvan »
Hi
When I change the camera status "None" to "Monitor", I get a white page and the change does not apply.
zm 1.36.28
centos 7
php 7.4.32
DV
KaiserPinguin
Re: bug: white page after save
Post by KaiserPinguin »
Same here (v1.36.29).
web_php.log says "View 'function' does not exist."
As a workaround, it is possible to change the state in the monitor settings.
lpadumorvan
Thanks for the workaround, it's work
DV
Zotter
Post by Zotter »
Confirmed
Just did a clean, new install of ZM on Fedora 36 using the RPMFusion repository. worked a charm, until I tried to change the 'function' from morecord to modetect from the console.
Making that change in the Monitor tab in the 'source' dialog not only affected the desired change, but did not yield a blank, white page with no changes.
Thanks!
