Page 1 of 1
Reason for not disabling frames and analysis images?
Posted: Sun Oct 16, 2022 1:13 pm
by krizzle
I l'm running ZM 1.36.29 and recently disabled both analysis images and frames and realized it's saving me a ton of storage. What are the reasons why I would want to keep them turned on? What extra information do the frames or amaysis images net me?
Thanks.
Re: Reason for not disabling frames and analysis images?
Posted: Sun Oct 16, 2022 11:13 pm
by bbunge
There is no good reason if your cam supports video.
With that said I have an old Foscam that I'm using that works better saving jpeg's at the low frame rate (5 FPS) I have set.
Posted: Mon Oct 17, 2022 12:22 am
by Andyrh
I turn it on when I am resolving a detection problem. It helps to see what was detected. Other than that I leave it off.
