Annke dvr DW81KD cameras C51BL
Posted: Thu Dec 01, 2022 11:32 pm
Just got my new ANNKE dvr and cameras today and there finally setup and working with zoneminder. Switched from wifi to hard wire now for better stability. I currently have them display in greyscale but color does work too. There is no need to use there app just a quick setup with the dvr and adjust a few settings is all the setup needed. I did switch streams from h265 to h264, adjusted FPS, and disabled audio which can be done in settings.
DVR Model: DW81KD purchased from walmart there product code is AU-DW81KD000-V4-OP
Cameras Model: C51BL purchased from ebay
Main Stream: rtsp://user:pass@yourip:yourport/H264/ch1/main/av_stream
Sub Stream: rtsp://user:pass@yourip:yourport/H264/ch1/sub/av_stream
