no console: help
smacgre
no console: help
Post by smacgre »
It was all working around a year ago. Now the console web access does not work. I have removed and re-installed all ZM code and followed the instructions in https://www.how2shout.com/linux/how-to- ... 20-04-lts/.
ps shows:
/usr/bin/perl -wT /usr/bin/zmdc.pl startup
/usr/bin/zmc -m 1
/usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
/usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
/usr/bin/perl -wT /usr/bin/zmwatch.pl
/usr/bin/perl -wT /usr/bin/zmupdate.pl -c
/usr/bin/perl -wT /usr/bin/zmtelemetry.pl
/usr/bin/perl -wT /usr/bin/zmstats.pl
running, but http/mypc/zm just displays a script file:
debugOn() ) { ob_start(); phpinfo(INFO_VARIABLES); ZM\Debug(ob_get_contents()); ob_end_clean(); }
if ( !$includeFiles || $view == 'error' ) { foreach ( getSkinIncludes('views/error.php', true, true) as $includeFile ) require_once $includeFile; } ?>
Re: no console: help
Sometimes clearing browser cache helps.
smacgre
Post by smacgre »
I tried it in a different browser (Chromium) which had its cache cleared, with the same results (though the script display was better formatted).
Why on earth is it displaying a script, rather then executing one? Some permissions wrong ... ?
I know nothing about this stuff - just a hopeful user.
smacgre
Post by smacgre »
I expect the current released software works, so there must be something in my machine which is persistent - left over from when it worked with older releases - which is making it not work now?
Anyone have any suggestions?
Crud. Yeah. Use this: https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
The thing you used is obsolete, even though it was "updated"; wrongly.
