Find Events that happen overnight
FSAB
Post by FSAB »
I'm trying to build a background filter that catches small events overnight such as camera IR and lighting changes that get around my preclusive filters, but I can't work out how to find events within a time period of (for example) 9PM and 5AM, across all days.
Setting a Start Time >= 21:00:00 and End Time <= 05:00:00 doesn't work, so does anyone have any ideas?
Re: Find Events that happen overnight
Try those with -15 hour and -7 hour. (tweak to suit.)
mikb
Post by mikb »
FSAB wrote: Tue Dec 06, 2022 9:48 am I'm trying to build a background filter that catches small events overnight such as camera IR and lighting changes that get around my preclusive filters, but I can't work out how to find events within a time period of (for example) 9PM and 5AM, across all days.
I suspect you've fallen into a "common sense English" vs "logic English" trap there.
There *is* no time of day that is more than 21:00 AND less than 05:00 :)
Name a number more than 21, but less than 5 ?
You might get away with Start Time >= 21:00:00 OR End Time <= 05:00:00 -- if it will let you do that -- that's logical (even though it won't accumlate overnight in the way you might intend -- 5 early hours of THIS morning, and 3 of THIS evening, missing out the day in the middle).
haus
Post by haus »
I have a filter like this.
( End Time - Less Than - 5:00:00
OR End Time - Greater Than - 23:00:00 )
AND End Date/Time - Greater Than - 24 hours ago
AND Cause - Not Equal To - Continuous
AND (Monitor Name - equal to - A
OR Monitor Name - equal to - B )
etc - I have one line for each outdoor camera
The first three lines are most relevant but I added the rest in case it helps.
FSAB
Post by FSAB »
mikb wrote: Tue Dec 06, 2022 6:27 pm I suspect you've fallen into a "common sense English" vs "logic English" trap there.
I'm perfectly aware of how timestamps work :P
I just assumed ZM either stored actual dates and times against events *or* did some processing of filter queries that looked at separate time and date values because said options were available in the search filters.
FSAB
Post by FSAB »
haus wrote: Thu Dec 08, 2022 4:10 pm I have a filter like this.
Excellent, it was this bit that worked - not sure why I didn't think of it before! :)
heathcote
Post by heathcote »
When it comes to time stamps, I'm an expert.
I'm assuming that ZM either maintains the precise time and date of the event, or processes the filter query by inspecting each individual date and time value, as detailed in the Find Filters interface.
