Hi, Due to a crash of a HD i reinstalled my PI4 to a new system and reinstall all the software again. I'am now on ZM 1.34.23 but are unable to use (configure) my Foscam FI9803P again. I use the same settings as on the previous version.
In VLC i can use the camera via RTSP.
In the config source page i can only select TCP, UDP, UDP multicast, HTTP tunnel where in the previous version i able to choose also RTP/unicast.
What is the correct config now for this camera?
Herman
Foscam FI9803p
Re: Foscam FI9803p
RTSP with either UDP or TCP usually works.
