No events / alerts?
dscheste
No events / alerts?
Post by dscheste »
Hello Team,
Installed 36.32 from scratch, setup my cams and zones, plenty of images and snapshots in /var/cache/events, but the console shows zeros and no zones, although each camera has at least one zone configured.
Where do I debug from here? Is my zmwatch even working?
Re: No events / alerts?
what do you have in Options -> Storage?
dscheste
Post by dscheste »
Only one default storage specified:
You should at least have columns Source Storage Events, and storage is missing on Console.
I've always had that column, but had it empty, too.
So try this; go into one or more cameras to the "Storage Area" option.
If the drop-down has two "Default", choose the second, bottom one. That fixed the empty columns for me, might do it for you.
dscheste
Post by dscheste »
changed to the second default storage, no diff.
Any logs I should start checking?
Might be worth having a go at installing the triggers
mysql -u zmuser -p zm < /usr/share/zoneminder/db/triggers.sql
Other than that, check your ZM logs.
