Page 1 of 1
No events / alerts?
Posted: Fri Dec 16, 2022 8:42 pm
by dscheste
Hello Team,
Installed 36.32 from scratch, setup my cams and zones, plenty of images and snapshots in /var/cache/events, but the console shows zeros and no zones, although each camera has at least one zone configured.
Where do I debug from here? Is my zmwatch even working?
Re: No events / alerts?
Posted: Sat Dec 17, 2022 8:12 am
by dougmccrary
what do you have in Options -> Storage?
Posted: Mon Dec 19, 2022 2:41 pm
by dscheste
Only one default storage specified:
Posted: Mon Dec 19, 2022 8:01 pm
by dougmccrary
You should at least have columns Source Storage Events, and storage is missing on Console.
I've always had that column, but had it empty, too.
So try this; go into one or more cameras to the "Storage Area" option.
If the drop-down has two "Default", choose the second, bottom one. That fixed the empty columns for me, might do it for you.
Posted: Tue Dec 20, 2022 1:21 am
by dscheste
changed to the second default storage, no diff.
Any logs I should start checking?
Posted: Tue Dec 20, 2022 8:24 am
by Magic919
Might be worth having a go at installing the triggers
mysql -u zmuser -p zm < /usr/share/zoneminder/db/triggers.sql
Other than that, check your ZM logs.
