Wansview W6 IP Camera ONVIF Setup
random_string
Post by random_string »
When I try to add a monitor through the ONVIF stream probe, it detects the camera, but I select the camera and click next, the detected profiles list is empty and I cannot click save. I've look around and I cannot find anything showing the function of the detected profile, or where to set them. Is there any way to get around this? I can get the camera feed to show up using RSTP, but the link is VERY unreliable. I have it set to a static IP at the router. One thing I've noticed is, when the RSTP link is down in zoneminder, the wansview app can easily show me a live view. I'm hoping the ONVIF stream will be more stable.
Also, is there a way to change settings in the camera without accessing the app? I hope to eventually block the cameras from "phoning home", but it would be nice if I could hack into it somehow to be able to change IP addresses or wifi passwords manually without having to send my wifi keys to PRC.
Re: Wansview W6 IP Camera ONVIF Setup
It might be worth trying with the current ZM version 1.36.x.
random_string
Magic919 wrote: Tue Dec 20, 2022 8:14 am It might be worth trying with the current ZM version 1.36.x.
Do you have any reason to think the newer version won't have the same problem? I ask because I don't want to spend days trying to get this running again, only to end up with exactly the same problem.
random_string
Can you tell me where those profiles are setup and what they do? I can't seem to find anything in the documentation about the profiles. Are they the camera profiles that are listed elsewhere in the presets page?
Profiles are a function of onvif and indicate capabilities of the camera, like pan and tilt.
Details at onvif.org
