Excessive RAM usage using "RECORD" Mode
Posted: Tue Dec 20, 2022 5:27 pm
Hi all -
I have a Ubuntu 20.04 running Zoneminder 1.36.32 with 9 cams of various manufactures (WYZE/TAPO/SV3C). The Majority of the cams are MODECT, one in MOCORD, and two in "RECORD" mode. All are working fine. However, the two set in "RECORD" mode (Wyze v3 / Tapo C310) are consuming and holding onto RAM. Most noticeably is the C310. This one seems to consume and keep RAM over the course of several days. I have had this one grow to over 16gb. I have some screen shots from TOP showing the RAM usage (Monitor #1) . Monitor #8 is the WYZE v3 in record mode too, but doesn't grow as much; but it does grow.
Here are the settings for the C310: (the Wyze v3 is the same only it's 1920x1080)
Tapo C310 20fps 2304x1296; save JPEGS: Disabled; Camera Passthrough; options crf=18,reorder_queue_size=150
Image Buffer size=4; Max Image Buff Size=325; Warmup=0; Pre/Post=25; Section Length=600
Is there something I have missed in the setup?
Here is output from TOP
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
4223 www-data 20 0 3211912 2.4g 75804 S 17.0 7.8 1:49.46 /usr/bin/zmc -m 1 (Record)
4464 www-data 20 0 2195668 1.7g 61072 S 13.0 5.5 1:20.65 /usr/bin/zmc -m 8 (Record)
4410 www-data 20 0 1507816 1.1g 61732 S 27.0 3.4 2:54.88 /usr/bin/zmc -m 7 (Modect)
4374 www-data 20 0 1231880 895396 61772 S 40.0 2.7 3:44.76 /usr/bin/zmc -m 4 (Modect)
4510 www-data 20 0 1132300 809572 86140 S 14.3 2.5 1:34.01 /usr/bin/zmc -m 9 (Nodect - lnk to id#10)
4742 www-data 20 0 966908 693676 60720 S 28.7 2.1 2:44.61 /usr/bin/zmc -m 15 (Modect)
4338 www-data 20 0 822464 550548 59964 S 28.0 1.7 2:49.40 /usr/bin/zmc -m 3 (Modect)
4288 www-data 20 0 770020 509620 60916 S 24.3 1.6 2:08.28 /usr/bin/zmc -m 2 (Modect)
4601 www-data 20 0 873836 494532 34796 S 4.7 1.5 0:30.59 /usr/bin/zmc -m 10 (Mocord)
Next Day:
4223 www-data 20 0 6837572 5.8g 66492 S 12.5 18.5 231:43.39 /usr/bin/zmc -m 1
4464 www-data 20 0 5639756 4.8g 51640 S 12.5 15.3 202:50.70 /usr/bin/zmc -m 8
4742 www-data 20 0 2886760 2.3g 51812 S 25.0 7.5 370:51.27 /usr/bin/zmc -m 15
4410 www-data 20 0 2165632 1.7g 51996 S 25.0 5.4 355:48.61 /usr/bin/zmc -m 7
Two Days later:
4223 www-data 20 0 9852476 8.6g 60200 S 14.6 27.4 462:44.70 /usr/bin/zmc -m 1
4464 www-data 20 0 5370052 4.5g 45876 S 11.6 14.4 408:38.51 /usr/bin/zmc -m 8
4410 www-data 20 0 2100752 1.6g 46284 S 20.6 5.1 714:51.03 /usr/bin/zmc -m 7
Three Days Later:
4223 www-data 20 0 13.1g 12.1g 60120 S 21.0 38.7 720:51.37 /usr/bin/zmc -m 1
4464 www-data 20 0 3214900 2.5g 45712 S 15.3 8.1 634:14.98 /usr/bin/zmc -m 8
4374 www-data 20 0 2490636 2.0g 46052 S 40.0 6.3 1491:18 /usr/bin/zmc -m 4
Thanks--
Next Day:
Two Days later:
Three Days Later:
Thanks--
