Zoneminder is Great and work fine.
First it s work with AXIS 205.
My config:
P4 2,8G / 1G RAM / FEDORA Core 1B / Spectra8
Apache 2.0.48-1.2 / Mysql 3.23.58-4 / ZM 1.19.1 / Kernel 2.4.22-1 /
BUT
after 12 hours memory full and pc stop !!!
Thank you for reply.
Philippe
problem memory
- zoneminder
- Site Admin
- Contact:
Re: problem memory
Hi Philippe,
Can you give me a bit more information? For instance what is it that fills up the memory? Are there any particular processes to do so? Running 'top' may help to determine this and if something is leaking you should it grow almost from the beginning. Notice that several ZM processes may appear to leak initially but this is only until all the shared memory has been paged into their process space which can take a half hour or so depending on your frame rate.
Phil,
Phil,
Re: problem memory
Hi Phil,
Ok I am looking the processes and I send to you more information asap.
Thank you mery much for help.
Philippe,
Philippe,
