Page 1 of 1
RTSP camera not working
Posted: Mon Dec 26, 2022 6:34 pm
by px03afk
Earlier this year I bought a Foscam FI9912P and got it working OK with Zoneminder 1.37.3 - despite there being a post suggesting the rtsp and 1.37 has problems. Since then I've tried a number of the later versions of 1.37 and cannot get it to work, even though the setup is the same. There are a number of errors that appear including:
zms: Zone 7/Front for monitor Front extends outside of image dimensions, (0,160), (639,479) != (480,640), fixing
zms: Cropping altered the number of vertices! From 4 to 5
zmc: No width and height in video stream. Trying again
I realise that 1.37 is a development version but as I have it working in 1.37.3 I wonder what has changed in the later versions.
Re: RTSP camera not working
Posted: Thu Dec 29, 2022 12:50 am
by dougmccrary
The camera isn't working, or the zones? Screenshot of zones if that's the problem?
Posted: Sat Dec 31, 2022 4:02 am
by px03afk
Not a zone problem. The camera isn't working at all with 1.37.28, nor was it with 1.37.20, but it is running fine on 1.37.3 and, unless I am missing something, the configurations are the same, although the later versions present the configuration slightly differently.
Posted: Sat Dec 31, 2022 11:26 am
by dougmccrary
Just to be clear, you can do an update from .3 to the latest master with no update errors - and this one camera quits?
Posted: Sat Dec 31, 2022 4:48 pm
by iconnor
The
Is the informative line I think. Basically it says that ffmpeg didn't get a keyframe in time. You might try setting probesize=50000 in Monitor->Source->Options, or set a larger Options->System-> WATCH_MAX_DELAY. Or both. Turn on debugging.
Posted: Sun Jan 01, 2023 5:04 pm
by px03afk
Mea Culpa. I was testing 1.37.28 on my backup machine where I thought I had run the new camera under 1.37.3 so to be sure I copied the database from my primary system and re-installed 1.37.3 and it didn't work. Turns out that I hadn't installed ffmpeg on the backup machine but, for some reason this didn't show up with 1.37.28, at least I didn't spot it. 1.37.3 gave me the hint very quickly and so after installing ffmpeg and then updating to 1.37.28 all is good.
Sorry to have been a nuisance.
Posted: Sun Jan 01, 2023 10:13 pm
by dougmccrary
Maybe that's something that should be verified at start-up.
As in you want to use this library? Well it's not installed, or I can't find it...
So happy new year, so far?
