Purge Old is not removing the old videos
homebrewdude
Post by homebrewdude »
If I go to the filter and "list matches" it will give me a list of things that should have been deleted.
I can manually select them and hit delete, and they do delete.
Why is not it automatically deleting? It used to. Not sure what version caused it to stop working.
Re: Purge Old is not removing the old videos
May not be related to your case, but see what happens running zmaudit
You are going to have to turn on debugging and go look at the logs for that filter. It will say why.
homebrewdude
I never got it to work.
Updated Mint which caused me to re-install zoneminder.
All works fine now...
