Page 1 of 1
Problem clicking to a specific spot during event playback
Posted: Wed Jan 04, 2023 12:00 am
by ZMBrian
I'm currently using 1.36.32, but this problem has persisted for me through several previous versions of 1.36 (and maybe even earlier). I did not have this problem with versions from about 3-4 years ago.
My cameras are in MOCORD recording at 10 min event intervals. During event playback, there is a playback progress bar (for lack of a better description) at the bottom that highlights detected motion in red. I can not click to anything early in the playback within about the first 2 minutes 20 seconds, it will simply go to the end of the recording. I can click to any point in the playback after about 2 minutes 20 seconds without issue. This is frustrating because if motion is detected at about the 2 minute mark, I have to wait the full 2 minutes to see it, I can't click ahead to right before the motion detection. If I do, it goes to the very end of the recording. Is this a known issue? Is there a work around?
Re: Problem clicking to a specific spot during event playback
Posted: Wed Jan 04, 2023 5:15 pm
by iconnor
Not a known issue. I reworked a lot of that code in master... might be interesting to see if it does it. I reworked it because it was kinda broken so it may be that I have not merged something back to 1.36.
Posted: Mon Feb 27, 2023 8:33 pm
by raptor320d
Hi Iconnor, and the Otherones,
at first, I thank you Iconnor for your effort.
im using ubuntu 22.04, yesterday I donwload version 1.36.33 BUT problem with playback still here.
I feel the problem from 1.36.x
this is reason i'm using ubuntu 18.04 for 2 years
problem definition:
you must mocord, and you take it - no mather what time and what speed you need, everything fa.k you =)
you not be abble take more than 1x speed and it is big problem to change a time position
this problem is times describe (not only) in this forum
please take it with a smile =)
thank you a lot
thanks in advance
Regards Petr
ps: (sorry for my english - still lerning)
Posted: Mon Feb 27, 2023 10:19 pm
by dougmccrary
FWIW, I'm not seeing this. I'm curious about your record settings, because I HAVE seen it, but fixed by changing record settings. Or so as I recall - it's been awhile.
And you are talking about recordings made by the current version ZM, not some old recording, I trust.
Posted: Tue Feb 28, 2023 7:34 pm
by raptor320d
hi dougmccrary
where is "record settings"?
there is camera/source or options, but nowhere something like "record"
Posted: Wed Mar 01, 2023 12:50 am
by dougmccrary
Yeah, sorry about that - Storage tab for the camera/monitor. Video Writer
Some cams seem to not work well with camera passthrough. One of mine is Encode, Auto, libx264 for e.g.
Posted: Wed Mar 01, 2023 7:20 am
by raptor320d
okok, i feeel it, this will be the problem, you can punch me
settings is:
- Storage area: my one
[--]from there, everyting is default[--]
- Save JPEGs: Frames + Analysis images (if avail.)
- Video Writer: disabled
- Optional Encoder Parameters (?): # Lines beginning with # are a comment
# For changing quality, use the crf option
# 1 is best, 51 is worst quality
crf=23
the last one - it is true?
second problem: why the timestamp disapears, it is still set
Posted: Wed Mar 01, 2023 9:53 am
by dougmccrary
Save .jpgs is useful for reviewing zone settings. You can turn that off or just to anlaysis images only.
Then turn on encoding with auto auto - that will enable your timestamp to be recorded.
Also, while it's not supposed to cause problems, it seems to help to remove those comments above crf=36
Let it run awhile and see what you get.
BTW, I'm not sure how long, if ever, it takes debug settings to get read, but a restart does it.
Posted: Thu Mar 02, 2023 6:36 pm
by raptor320d
problem is suppressed, i setup x254 codec, with "auto" it doesnt work properly.
it works, but the cursor hopping when i set some time (position)
but works
second problem with timestamph was like this:
viewtopic.php?t=30228
in the log in gui i can see that defalut font is in the ./zoneminder/fonts instead of /zoneminder/www/fonts
thanks dougmccrary
Posted: Sun Mar 05, 2023 9:06 pm
by raptor320d
the problem is almost the same,
i can select any position, BUT, "mocord" record in 10 minutes block.
every video seem to be 9:59 in the description, but when i try to see it, it have only about 15 sec.
setting is:
Save JPEGs: Frames + analysis
Video Writer: encode
h254
libx254
#crf=23
almost the same like version 1.34
please help
Posted: Mon Mar 06, 2023 5:53 am
by dougmccrary
h254
libx254
#crf=23
please help
Top
probably drop JPEGs to analysis only
In optional params, just "crf=23" no quotes
Options->Config has EVENT_CLOSE_MODE time ?
