ZoneMinder on OpenSuSE issues, need help!
Posted: Sun Jan 08, 2023 1:16 am
I have been struggling (and making progress) on installing ZM 1.36 on an OpenSuSE 15.4 system. I got my copy from a community maintained repo for OpenSuSE and strongly suspect that there were/are problems with how the integrators set up ZM. I could provide a list of problems I found and had to find a fix for, if interested.
I have managed to get ZM to come up, and even display images from my cameras, but only for a short period of time. ZM will suddenly stop (mostly when viewing a live stream from a camera, but not always.) and return to the login page. A couple of observations I have noted, from the log files -
The first odd thing I see is that the apache-error.log file is constantly reporting (every few seconds while I am logged in and using ZM) "Login successful ..." messages. This indicates that behind the scene, ZM is having troubles keeping me logged in, and apparently it's attempts to keep me logged in eventually soon fails, causing ZM to log me out, and dumps me back to the manual login screen.
Also in the apache-error.log file I am seeing a lot of this error, for which I do not have a solution yet. I have not found where I could get the file wp-login.php -
The second thing of concern to me is that the zm service itself terminates quickly after starting it up. It seems to last long enough to spawn a lot of sub-processes -
I have not found a real reason why zm.service is failing to start other than it appears (from looking at the code in zmpkg.pl) that neither stopping or restarting the zm service changes the state from "RUNNING". And because zmpkg.pl thinks the zm service is already running, it reports an error when
it tries to start the zm service again.
ASIDE NOTE: zmpkg.pl is dropping the reason for returning an error (Already running), into the bit bucket. This is bad programming practice, it should be logged at least, better yet reported to the user visually.
The following shows that even though zm.service failed to start, it at least spawned off a lot of child processes before failing.
Any ideas on how to get the zm.service and ZoneMinder's gui to run reliably? Much appreciate any and all offers of help, thanks in advance....
Marc..
P.S. It is very aggravating to spend time writing up a complex email, such as this one, only to find that the web server has timed you out, forces you to re-log in, and then drops everything you had typed up, on the floor. The one thing I remember most, from my computer science classes many many years ago, is that the first cardinal rule of good programming practices, is to NEVER NEVER NEVER lose user data! This web interface badly violates that rule!
tail -f apache-error.log
Sat Jan 07 15:45:27.308437 2023] [php7:notice] [pid 17107] [client 127.0.0.1:50752] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
[Sat Jan 07 15:45:32.343346 2023] [php7:notice] [pid 17107] [client 127.0.0.1:50752] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
[Sat Jan 07 15:45:37.330665 2023] [php7:notice] [pid 17107] [client 127.0.0.1:50752] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
[Sat Jan 07 15:45:42.310539 2023] [php7:notice] [pid 17107] [client 127.0.0.1:50752] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
[Sat Jan 07 15:45:47.331616 2023] [php7:notice] [pid 17107] [client 127.0.0.1:50752] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
[Sat Jan 07 15:45:52.308826 2023] [php7:notice] [pid 17107] [client 127.0.0.1:50752] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
[Sat Jan 07 15:45:57.339437 2023] [php7:notice] [pid 7657] [client 127.0.0.1:52174] INF [Login successful for user "Marc"], referer: http://localhost/zm/index.php?view=console
apache-error.log:[Wed Jan 04 13:53:56.941447 2023] [php7:error] [pid 21536] [client 130.61.143.194:46276] script '/usr/share/zoneminder/www/wp-login.php' not found or unable to stat
nova:/var/log/zm # systemctl stop zm
nova:/var/log/zm # systemctl start zm
Job for zm.service failed because the control process exited with error code.
See "systemctl status zm.service" and "journalctl -xeu zm.service" for details.
nova:/var/log/zm # systemctl status zm
× zm.service - ZoneMinder Video Surveillance System
Loaded: loaded (/usr/lib/systemd/system/zm.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2023-01-07 16:30:31 PST; 11s ago
Process: 26983 ExecStartPre=/usr/bin/zm_database_init --non-interactive (code=exited, status=0/SUCCESS)
Process: 26984 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
Jan 07 16:30:31 nova zmpkg[26984]: INF [Command: start]
Jan 07 16:30:31 nova sudo[26990]: root : PWD=/usr/share/zoneminder/www ; USER=wwwrun ; COMMAND=/usr/bin/true
Jan 07 16:30:31 nova sudo[26992]: root : PWD=/usr/share/zoneminder/www ; USER=wwwrun ; COMMAND=/usr/bin/zmdc.pl check
Jan 07 16:30:31 nova systemd[1]: zm.service: Control process exited, code=exited, status=1/FAILURE
Jan 07 16:30:31 nova systemd[1]: zm.service: Failed with result 'exit-code'.
Jan 07 16:30:31 nova systemd[1]: Failed to start ZoneMinder Video Surveillance System.
nova:/var/log/zm # ps aux | grep zm | grep -v emacs | grep -v grep
wwwrun 6229 18.1 0.5 573780 95444 ? Sl Jan06 426:50 /usr/bin/zmc -m 9
wwwrun 6491 18.2 0.5 573788 96556 ? Sl Jan06 429:03 /usr/bin/zmc -m 8
wwwrun 17138 8.9 0.6 574704 98880 ? Sl 10:25 32:24 /usr/bin/zmc -m 10
wwwrun 17143 1.5 0.2 551352 46968 ? Sl 10:25 5:44 /usr/bin/zmc -m 2
wwwrun 17155 2.9 0.3 551904 52064 ? Sl 10:25 10:30 /usr/bin/zmc -m 11
wwwrun 18258 2.7 0.3 551384 50804 ? Sl 15:21 1:50 /usr/bin/zmc -m 3
wwwrun 20189 0.0 0.0 78816 15768 ? S Jan01 5:03 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
wwwrun 20293 0.0 0.3 125844 58140 ? S Jan01 0:35 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
wwwrun 20299 0.0 0.4 134316 66496 ? S Jan01 0:07 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
wwwrun 20305 0.0 0.5 149572 81320 ? S Jan01 0:10 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=3 --daemon
wwwrun 20311 3.0 1.1 251680 185584 ? S Jan01 269:03 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
wwwrun 20317 0.0 0.1 76172 18396 ? S Jan01 2:52 /usr/bin/perl -wT /usr/bin/zmwatch.pl
wwwrun 20324 0.0 0.1 100656 32252 ? S Jan01 0:00 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
wwwrun 20329 0.0 0.0 111688 7072 ? S Jan01 0:00 /usr/bin/perl -wT /usr/bin/zmtelemetry.pl
wwwrun 20337 0.0 0.0 75960 15084 ? S Jan01 0:02 /usr/bin/perl -wT /usr/bin/zmstats.pl
wwwrun 25975 8.7 0.6 581776 107264 ? Sl 16:22 0:24 /usr/bin/zmc -m 5
wwwrun 26020 11.8 0.5 573560 94056 ? Sl 16:23 0:31 /usr/bin/zmc -m 6
wwwrun 26176 9.3 0.5 573840 87832 ? Sl 16:24 0:17 /usr/bin/zmc -m 4
wwwrun 26575 0.8 0.3 424688 52204 ? Sl 16:27 0:00 /usr/bin/zmc -m 1
wwwrun 26586 3.1 0.3 424688 52144 ? Sl 16:27 0:00 /usr/bin/zmc -m 12
Marc..
