My install seemed to go well. I started the zoneminder process. But I see nothing in the apache2 /var/www/html/ ?
Yet the install says to browse to http://hostname_or_ip/zm? What am I missing?
No "zm" in /var/www/html"?
Re: No "zm" in /var/www/html"?
I use LXD to create various containers that I create, such as websites or web apps. One container runs haproxy as a reverse proxy. This works fine for me using sub-domains to route to the proper container.
I have installed zoneminder in a LXD container.
root@mycamera:/etc/apache2# apachectl -S
VirtualHost configuration:
*:80 mycamera.lxd (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Main DocumentRoot: "/var/www/html"
Main ErrorLog: "/var/log/apache2/error.log"
Mutex default: dir="/var/run/apache2/" mechanism=default
Mutex mpm-accept: using_defaults
Mutex watchdog-callback: using_defaults
Mutex rewrite-map: using_defaults
PidFile: "/var/run/apache2/apache2.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: ENABLE_USR_LIB_CGI_BIN
User: name="www-data" id=33
Group: name="www-data" id=33
So i guess the question is, is this doable? How would I access this virtual host?
Define: DUMP_VHOSTS
When I try to browse to zoneminder, I am getting:
503 Service Unavailable
No server is available to handle this request.
So I have a subdomain that haproxy uses to forward to the correct LXD container which holds the zoneminder install. I actually have multiple sub-domains that I use for haproxy to route to specific LXD containers and they work fine. Just this one for zoneminder is not working?
here is my haproxy.cfg for zoneminder:
front_end http_1b
bind *:80
bind *:443 ssl crt /etc/haproxy/certs/
http-request redirect scheme https unless { ssl_fc }
acl cameras hdr(host) -i mycamera.streamingworld.us
use_backend camera if cameras
backend camera
balance leastconn
http-request set-header X-Client-IP %[src]
redirect scheme https if ! { ssl_fc }
server zmcamera mycamera.lxd check ssl verify none
Note that I use the above formats for a bunch of other sub-domain LXD containers and they work fine.
Thanks.
front_end http_1b
bind *:80
backend camera
balance leastconn
Thanks.
I don't really want to get involved with all that madness, but I'll repeat that you need to use the virtual host for zoneminder.
Madness to some makes sense to others.
I am looking for someone who can advise on using Zoneminder behind a reverse proxy. How to incorporate the Virtual Server?
Also i am not expert on Apache2 and Virtual servers.....
So why doesn't Zoneminder install where it makes sense.../var/www/html/ ????
