Page 1 of 1
Why is zm capturing in monitor mode?
Posted: Mon Jan 23, 2023 1:58 pm
by mkuhnla
I setup zoneminder to watch a cat-door and raise an alarm if a foreign cat enters my home. This works great and I thank everybody who works for this great piece of software.
As far as I understand the system, alarms should only be raised if the monitor is in modect mode. To disable my alarms, I switched the monitors to "monitor"-mode and to my surprise, alarms are raised even in this mode.
The UI-Console shows "Capturing" even in monitor-mode and alarms are raised, if an event occurs. My expectation is, in monitor mode no capturing should occur and no events should be triggered.
Am I thinking wrong or I am doing wrong?
Some advices are welcome
Regards
Markus
Re: Why is zm capturing in monitor mode?
Posted: Mon Jan 23, 2023 11:25 pm
by dougmccrary
I don't remember for sure what 1.34 looks like. Sounds like a bug.
You might consider upgrading to 1.35, which has finer control over recording and detection.
Posted: Tue Jan 24, 2023 1:30 pm
by mkuhnla
Thanks for your reply.
I upgraded to 1.36 and now there is another issue. I will post it in the proper forum.
Regards
Markus
