[Solved] After Upgrade from 1.34 to 1.36.26 Modal Popups in WebGui not working
Posted: Tue Jan 24, 2023 1:45 pm
Hi there,
I just upgraded zm from 1.34 to 1.36.26 on a Debian Bullseye installation and the Popup-Menus at the Web-Gui are not working anymore.
If I click on "Monitor" at the console, nothing happens at the GUI. I find the following entry in the log file:
After upgrading I did
Unfortunately this doesn't help.
Any ideas?
Regards
Markus
web_js[29218].ERR [192.168.55.23] [TypeError%3A%20%24j(...).modal%20is%20not%20a%20function] at zm/cache/skins_classic_views_js_console-base-1663347595.js line 172
zmupdate.pl
zmupdate -f
Any ideas?
Regards
Markus
