Annke C800 4k Camera
Maximo1970
Post by Maximo1970 »
I've just bought one of these cameras to see if it's worth upgrading my existing cameras. Just looking to see if anyone else has any of these cameras and what settings they're using.
Re: Annke C800 4k Camera
Try the search box up there ^
Maximo1970
Magic919 wrote: Mon Jan 30, 2023 1:24 pm Try the search box up there ^
Any when there are no results, I do what next?
I have one, works great. It is a hikvision.
Please note that your computer likely cannot handle decoding and doing motion detection on the 4k stream.
Hand in your membership card.
search.php?keywords=annke+c800
Maximo1970
iconnor wrote: Mon Jan 30, 2023 2:07 pm I have one, works great. It is a hikvision.
Thanks Isaac, time to move away from VM's with loads of CPU's and RAM for something dedicated to the job and with a massive GFX card? Or do I just drop down a resolution and play around with the various settings both on the camera and ZM?
graphics card won't help much.
It just isn't feasible to decode and do anything else with the 4k stream. Need to just record it without decoding. Trigger it with the substream. Or use on camera motion detection and janus.
lbm
Post by lbm »
Just bought one of these a few weeks back as well. It works with RTSP just fine.
I've read some rumors that it required their software to setup, and that it should be activated. I havent done either of it. An IP was assigned from DHCP, and from there I could access the WebUI and reconfigure it.
Even with using an NON IE browser, which is progress from the current real hikvision cameras I have :D . (Live streaming does not work, but the setup does).
rossnewton
Post by rossnewton »
iconnor wrote: Mon Jan 30, 2023 2:07 pm I have one, works great. It is a hikvision drift hunters
Me too :roll:
Agatha767
Post by Agatha767 »
lbm wrote: Wed Feb 01, 2023 8:36 am Just bought one of these a few weeks back as well. It works with RTSP just fine.
I've read some rumors that it required their software to setup, and that it should be activated. I havent done either of it. An IP was assigned from DHCP, and from there I could access the WebUI and reconfigure it.tiny fishing
Oh, useful info. Thanks.
RogerP
Post by RogerP »
I guess you're on Windows? I use Arch Linux https://endeavouros.com/. I am having a lot of trouble seeing anything but thumbnails in ZM from my three C800s. Also, lots of drops outs. And, no, I don't use wifi! :wink:
But today is the first time I have tried ZM, so I am still reading the manuals. I'm using RTSP, with H264 as the codec although they are H265 cameras.This advice comes from the Annke manual, which is pretty useless BTW as it assumes you're on Windows and using a thing called IE.
Have you managed to enable ONVIF?
