Page 1 of 1
Rate/Scale based on bandwidth setting
Posted: Fri Apr 09, 2004 3:33 am
by pchan
Is it possible to set the scale and rate based on bandwidth setting?
If i'm connected to the LAN directly, I can view at full scale. When viewing events remotely, I generally prefer to set the scale to 1/2 or 1/3 to try and reduce bandwidth.
Re: Rate/Scale based on bandwidth setting
Posted: Fri Apr 09, 2004 3:39 am
by pchan
Another follow up - is it possible to make STILLs the default for low bandwidth (or medium)?
Posted: Sun Apr 11, 2004 5:50 pm
by fernando
mm sounds good. but maybe can be set by each user..
so each user can set his view parameters.
and admin can set the highest bandwidhts of users.
