Page 1 of 1
does purge when full only purge active cameras?
Posted: Wed Feb 08, 2023 12:41 pm
by aarons6
so i was checking my drive and i noticed that an old camera that i took out and replaced still has some videos on one of my drives.
i have purge when full enabled and its at 99%.
when i go into zm and i click on the total events down at the bottom, it loads those old videos as the first few pages.
these old videos should have been purged months ago.. but they are still there.
any reason why they were skipped?
Re: does purge when full only purge active cameras?
Posted: Wed Feb 08, 2023 9:40 pm
by dougmccrary
Strange stuff sometimes happens...did you try running zmaudit.pl?
Posted: Thu Feb 09, 2023 1:00 am
by aarons6
dougmccrary wrote: ↑Wed Feb 08, 2023 9:40 pm
its already running as normal.
Posted: Thu Feb 09, 2023 1:12 am
by iconnor
Are they archived? ZM will not delete archived video.
Posted: Thu Feb 09, 2023 12:28 pm
by aarons6
iconnor wrote: ↑Thu Feb 09, 2023 1:12 am
no they arent archived, i just turned the monitor off and put it to none.
Posted: Thu Feb 09, 2023 10:09 pm
by dougmccrary
So you made a new entry for the replacement camera.
Is the name you gave the new one the same as the old?
Posted: Tue Feb 14, 2023 6:40 am
by aarons6
dougmccrary wrote: ↑Thu Feb 09, 2023 10:09 pm
no, i just turned off the old camera and left it so it had the old videos, just incase i needed them.
but i figured it would eventually delete them to recover the drive space. but it didnt.
i just deleted them manually.
Posted: Tue Feb 14, 2023 7:36 am
by dougmccrary
I guess that's worth a check.
Posted: Tue Feb 14, 2023 12:29 pm
by pat2
OT:
Doug, upgraded to the new v2 version of 1.36.33, released few hours ago, fyi it's available in the "proposed" repo
Isaac, thanks to release the xenial version too in the proposed repo
Posted: Fri Mar 31, 2023 10:22 pm
by dougmccrary
So, ran a test to see if old records would delete if the camera was simply turned off.
My result was "Yes, they are".
Don't know what happened in your case.
Posted: Sat Apr 01, 2023 11:39 pm
by iconnor
Purge when full filter does not by default look at monitor status. It should sort by age, deleting oldest first.
It might delete more events from 1 monitor over another, if they were more frequent, but literally it should delete oldest first.
Posted: Mon Apr 03, 2023 8:34 am
by dougmccrary
Yes. That's been my experience, precisely.
Posted: Wed Jul 26, 2023 12:53 am
by bbunge
I've found for my installs that purge at 95% disk full can be a problem. Especially with a many monitors recording. for a "normal" install I change the 95% to 85% which allows a free space cushion for the purge when full to catch up with the disk writes. By "normal" I mean the ZM install on a single disk. With the storage on a separate disk you can set up a purge when full filter for that disk.
