zm and zmninja don't stream over ssl
Posted: Fri Feb 10, 2023 5:34 pm
It may have happened after the updates, now the latest version.
Today I found out that the image in zmninja has stopped being displayed. The portal is detected, authorization passes, but I do not see the image from the cameras. I used to go to http://ip/zm .
After studying the forum, I made a dns name, https + lets'encrypt certificate. Now everything is the same, for verification I go through the web version by domain name - everything is OK with the certificate, but there is no video.
Configured via NAT (requests to ports 80 and 443 external ip > internal ip). The certificate is ok, I can log in both from the application and from the web by name, but there is no video. The assistant in the android app shows that everything is fine, detects portals and comes in, but there is no video.
At the same time, in the local network, when logging in via the internal ip, everything works as before.
Please help me figure out how to return the work of the external portal and zmninja.
