Hardware
HP ProLiant ML310e Gen8 v2
Xeon® E3-1270 v3
8 Gb Ram
AMD RX 550 2Gb
ILO on board video
7 pcs: IP camera 5MP (2592x1944) Video Codec H.265/H.264 (HP/MP/BP)/MJPEG
configured for H.264
Software
CentOS 7.9
Clear install ZoneMinder 1.36
For all cameras the same logs:
"20.02.2023, 17:37:43 GMT+5",zmc_m4,,58292,INF,"name: 53900 - Capturing at 25.04 fps, capturing bandwidth 478542bytes/sec Analysing at 0.00 fps",zm_monitor.cpp,1681
"20.02.2023, 17:37:42 GMT+5",zmc_m1,,57887,WAR,"Decoding is not keeping up. We are 887 seconds behind capture.",zm_monitor.cpp,2625
I can't figure out what the problem is. please help
Spam in log
Re: Spam in log
It says "Decoding is not keeping up"
Your CPU can't cope with the work you are giving it (in real time).
Re: Spam in log
how to understand what kind of work an existing processor can handle? And which one is needed to cope with the current set of cameras?
I have high load on the processor even if I leave only three cameras on.
And this spam in logs.
Сonsidering the fact that there are examples of 90 cameras on the i7-6700 and a pair of gtx 610 on the TRASSIR system work fine.
I can assume that there is still something wrong in the settings of the ZM. Because the power of hardware, in theory, should be enough. Yes, I have not yet managed to configure vaapi to unload the processor. At the same time, two cameras are set to record continuously. with the option "camera passthrought". And everything is fine on the recordings.
