The zoneminder-containers/zoneminder-base container starts in the STOPPED state and I cannot start it from the UI.
There's these errors in the logs:
[zoneminder-service] 2023-02-22 14:15:02.989250625 INFO Starting ZoneMinder...
[zoneminder] 2023-02-22 14:15:11.184118221 local1.err: Feb 22 14:15:11 zmdc[922]: FAT [Can't connect to zmdc.pl server process at /zoneminder/run/zmdc.sock: No such file or directory]
[zoneminder] 2023-02-22 14:15:11.186904572 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl startup", output is "Starting server", status is 255]
[zoneminder] 2023-02-22 14:15:11.240608636 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl start zmfilter.pl --filter_id=1 --daemon", output is "Unable to connect to server using socket at /zoneminder/run/zmdc.sock", status is 255]
[zoneminder] 2023-02-22 14:15:11.292992424 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl start zmfilter.pl --filter_id=2 --daemon", output is "Unable to connect to server using socket at /zoneminder/run/zmdc.sock", status is 255]
[zoneminder] 2023-02-22 14:15:11.345458692 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl start zmwatch.pl", output is "Unable to connect to server using socket at /zoneminder/run/zmdc.sock", status is 255]
[zoneminder] 2023-02-22 14:15:11.397436936 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl start zmupdate.pl -c", output is "Unable to connect to server using socket at /zoneminder/run/zmdc.sock", status is 255]
[zoneminder] 2023-02-22 14:15:11.449087879 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl start zmtelemetry.pl", output is "Unable to connect to server using socket at /zoneminder/run/zmdc.sock", status is 255]
[zoneminder] 2023-02-22 14:15:11.501916608 local1.err: Feb 22 14:15:11 zmpkg[916]: ERR [Unable to run "/usr/bin/zmdc.pl start zmstats.pl", output is "Unable to connect to server using socket at /zoneminder/run/zmdc.sock", status is 255]
[zoneminder-service] 2023-02-22 14:15:11.506256361 INFO ZoneMinder is up! Proceeding to monitoring.
zmpkg.pl start
Any clue to what could be happening?
