please see screenshot.
I have a 4 TB second drive "ExternalUSB" and want to fill it up to 80% with events.
Currently its about 9766 Events for the 48% used, each Event is about 60 MB in size.
But ZM keeps deleting everything down to 48%.
What is wrong with my filter?
Thank you for your help, I got stuck there.
Please help with Purge filter
- purge.png (43.33 KiB) Viewed 1434 times
Re: Please help with Purge filter
"List Matches" gives always an empty List regardless the setting of the "disk Percentage"
"Export Matches" Gives always 100 Results, regardless the setting of the "disk Percentage"
"Debug" and execute the Query in PHPMyAdmin always has 100 Results, because it seems the disk percent is not used in the Query.
Assumption:
The "Disk Percent" is not taken from the "ExtremalUSB" but instead of the "Default" and then used in the Query.
So when Default hits 80%... it keeps deleting from "ExtermalUSB" until the Default is back below 70% (what is Random, because it is only the system drive.
So Question is:
How is "Disk Percent" determined, and from which drive the percent will taken? How To specify "If ExternlUSB > 80%" ?
Assumption:
So Question is:
Found this snippet in Filter.php
case 'DiskPercent':
// Need to specify a storage area, so need to look through other terms looking for a storage area, else we default to ZM_EVENTS_PATH
if ( ! $StorageArea ) {
for ( $j = 0; $j < count($terms); $j++ ) {
if ( isset($terms[$j]['attr']) and $terms[$j]['attr'] == 'StorageId' and isset($terms[$j]['val']) ) {
$StorageArea = new Storage($terms[$j]['val']);
break;
} // end foreach remaining term
if ( ! $StorageArea ) $StorageArea = new Storage();
} // end no StorageArea found yet
$sqlValue = getDiskPercent($StorageArea);
break;
But I can not find a similar logig in .pl files used in "zmfilter.pl". Seems this is only implemented in the preview in PHP and not in the actual Filter execution cronjob?
case 'DiskPercent':
break;
break;
What size does zm show in the options page for USB disk?
You're right, list matches doesn't work for purge filters.
What happens if you set the filter to 90?
What does your default filter look like? It must specify default.
Thank you for reading my issue.
2 ExternalUSB /var/usbplatte1/zoneminder local Medium 1.73TB of 3.58TB 9825 using 0.92TB
I can try it, but it will take a few month to see the result.
There is no other filer.
I have the default "Update DiskSpace" and changed the default "Purge when Full" to this new drive.
Only those two are there.
Idea/Qustion:
Do I need to build a "Update DiskSpace" Filter also for each drive in order to work properly? Currently the "Update DiskSpace" is wihtout disk name. Is it then updating all or only default?
Probably.
I have a purge filter and diskspace filter for each drive. Seems to be required, and I think is consistent with that code you found.
Your disk in Storage looks OK.
You should not need a storage specification for update disk space. It cares not about the storage area.
And so it is. Just verified that one disk space filter does both my drives.
