Cannot write to event folder
Posted: Thu Mar 16, 2023 3:24 pm
I have a new install on Debian 11 and followed the installation guide with dedicated disk mounted using systemd. The disk mount and binds have been verified. I am getting the error:
"Cannot write to event folder sdb1/zoneminder/events. Check that it exists and is owned by the web account user."
First question: the installation guide states in Step 4: "Create a config file under /etc/zm/conf.d ....." which has been done. I am confused on the path for "ZM_DIR_EVENTS=/full/path/to/the/events/folder". Should the be 'sdb1/zoneminder/events' or 'var/cache/zoneminder/events'?
In either case of calling out the path (dev/sdb1 or var/cache...) I get the same error.
I have checked that the ownership and write permission is with www-data.
I'm looking for suggestions on what to correct or further investigate.
