1000 errors in apache access log
tito
Post by tito »
Hi Community!
Can anyone help?
My apache access.log is full off errors like this:
I think it is something from API but I can't find a solution.
System: Ubuntu Server 22.04
"GET /zm/cgi-bin/zms?mode=single&monitor=2&token=e........ HTTP/1.1" 200 136240 "-" "Jetty/9.4.46.v20220331
Re: 1000 errors in apache access log
Doesn't look like a ZM problem.
Where are those calls coming from?
pat2
Post by pat2 »
hi,
it doesn't seem errors. it seems they are access logs related to ZM usage.
How is it working ZM? and ZMNinja?
if fine, probably they are only logs.
mikb
Post by mikb »
They are not errors.
If you look part way down the log line, you'll see a "200" which is "OK"!
Return/status codes for HTTP and Email handling follow a similar pattern, the first digit is the CLASS of response (Informational, Success, Temporary Failure, Permanent Failure) ... see https://en.wikipedia.org/wiki/List_of_HTTP_status_codes
