Page 1 of 1
Can't add monitor: Path must be set a valid value
Posted: Thu Mar 23, 2023 5:24 pm
by tr3b0r
Trying to add a monitor to a new install of zoneminder
I can't switch from the General page.
and
when i try to save that it a popup message:
my_zoneminder_server says
Height must be set a valid value
Width must be set a valid value
                                                              OK
I did two zoneminder installs yesterday and it worked fine.
Help please
Re: Can't add monitor: Path must be set a valid value
Posted: Thu Mar 23, 2023 10:35 pm
by dougmccrary
Please give the exact steps to this problem.
How many monitors do you have?
Have you done any updates? What OS?
Posted: Thu Mar 23, 2023 11:54 pm
by iconnor
Check for javascript errors
Posted: Thu May 25, 2023 10:01 am
by lat123
Hi Iconnor,
How can I check the javasciprt error ? Thank you.
By the way I have this error too
[zoneminder] 2023-05-25 16:31:42.263259957 local1.warn: May 25 16:31:42 web_php[344]: 5/25/23, 4:31:42 PM GMT+7.262190 web_php[344].WAR [172.20.0.1] [Specified value rtpRtsp not in contents: Array
[zoneminder] 2023-05-25 16:31:42.263325541 local1.warn: May 25 16:31:42 web_php[344]: (
[zoneminder] 2023-05-25 16:31:42.263327291 local1.warn: May 25 16:31:42 web_php[344]: [v4l2] => Video For Linux version 2
[zoneminder] 2023-05-25 16:31:42.263328708 local1.warn: May 25 16:31:42 web_php[344]: [v4l1] => Video For Linux version 1
[zoneminder] 2023-05-25 16:31:42.263339708 local1.warn: May 25 16:31:42 web_php[344]: )] at includes/functions.php line 484
[zoneminder] 2023-05-25 16:40:28.230187300 local1.err: May 25 16:40:28 web_php[340]: 5/25/23, 4:40:28 PM GMT+7.228099 web_php[340].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 183
[zoneminder] 2023-05-25 16:40:28.247228107 local1.err: May 25 16:40:28 web_php[340]: 5/25/23, 4:40:28 PM GMT+7.246466 web_php[340].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 199
[zoneminder] 2023-05-25 16:42:37.151074384 local1.err: May 25 16:42:37 web_php[343]: 5/25/23, 4:42:37 PM GMT+7.149912 web_php[343].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 183
[zoneminder] 2023-05-25 16:42:37.162774583 local1.err: May 25 16:42:37 web_php[343]: 5/25/23, 4:42:37 PM GMT+7.162060 web_php[343].ERR [172.20.0.1] [Unable to list network interfaces, status is '127'. Output was:<br/><br/>] at skins/classic/views/onvifprobe.php line 199
Posted: Sun Jun 18, 2023 11:08 pm
by shaklee3
Hi, new user of ZM setting it up on Ubuntu for the first time. I have this same issue and cannot add any of my cameras. I don't see any javascript errors either.
Posted: Mon Jun 19, 2023 12:05 pm
by bbunge
shaklee3 wrote: Sun Jun 18, 2023 11:08 pm Hi, new user of ZM setting it up on Ubuntu for the first time. I have this same issue and cannot add any of my cameras. I don't see any javascript errors either.
What install procedure did you use?
