Page 1 of 1
Reboot button in Zoneminder GUI
Posted: Tue Mar 28, 2023 9:28 am
by djtracer
Ability to reboot the hosting OS from Zoneminder GUI. Sometimes the server cant be accessed via ssh, and a hard reset is not good.
Re: Reboot button in Zoneminder GUI
Posted: Tue Mar 28, 2023 3:18 pm
by iconnor
This exists, you just need to turn it on and setup the sudo permissions.
Options->System->Shutdown
Posted: Tue Mar 28, 2023 3:25 pm
by djtracer
Shot buddy!
Shutdown button disappeared when upgraded to 1.36.33 for some reason.
Posted: Wed Mar 29, 2023 9:02 am
by dougmccrary
If you're on the latest 1.36.33 you should see it adjacent to the status "RUNNING".
Posted: Wed Mar 29, 2023 10:19 am
by djtracer
Yes same with previous version, but when upgraded it vanished, I have retrieved it using the settings. Reason I brought this up, because I thought it had originally been removed from the build.
Just as a check on the upgrade side, I have upgraded all 6 of my ZoneMinder machines, and this problem only occurred twice, on the above mentioned
machine and another. The 2 machines in question were installed using minimal ubuntu, whereas the others have full server installed.
Posted: Wed Mar 29, 2023 10:20 pm
by dougmccrary
meaning desktop? Might be a clue, although I run minimal desktop and haven't seen that.
Posted: Wed Mar 29, 2023 10:54 pm
by iconnor
I can't think of anything in the updates that would affect it... other than maybe .. I think there was a config table change, so zmupdate.pl -f would have been run.
Do we know if the update was from .32 to .33 that made it disappear, or something earlier...
Posted: Fri Mar 31, 2023 8:17 am
by djtracer
When I updated all the other machines (5 of them) 1 extra one did the same thing, it was from.32 to .33 and it was a minimalistic ubuntu installation.
The other 4 were also .32 to .33 and had no issues.
