Bug: 1.37.37 - No sum in console view of column "month"
Zoneminder 1.37.37
Ubuntu 20.04.06 LTS
In a console view there is no sum (number of events or events sizes) of column "Month". It is showing zero. Hour, day and week are working as expected. Please see attached image. Functionality not affected by this. Also Archived column is not shown and zones sum is moved to the left. Thank you for your hard work it is appreciated.
Ubuntu 20.04.06 LTS
- ZoneMinder 1.37 Bug.jpg (115.1 KiB) Viewed 2186 times
Re: Bug: 1.37.37 - No sum in console view of column "month"
I'm not seeing that on 1.37.37~20230407133847-
You seem to be missing the archive column, which may be why the zones are to the left.
It is same in 20230410154831. Latest Chrome and latest Firefox show same error.
When it is clicked on "zero" this is URL that it goes to
http://xxx.xxx.xxx.xxx/zm/index.php?vie ... limit%5D=0
So, my opinion is that archived column is OK, moved to the left because sum of month column is actually missing.
everything is shifted over, your screenshot doesn't include the whole screen, The missing column is something on the left...
Actually sir, you're absolutely right. Everything is shifted to the left. Checked in both latest Firefox and Chrome. Thank you for your hard work.
So what's missing?!
The Month column total events and storage should be >0
I see it too, now.
edit:
Crud. Yeah I was looking at the archived column, which is correctly 0.
I see it too, now.
edit:
Nothing is missing, it is just offset to the left. Good eye. Minor nuisance.
There IS something missing, that's why they are shifted! I'd like to figure it out so I can fix it!
Can't find what is missing. I don't know if it helps, but I started noticing this shift around same time as paging "problems" occurred.
No mater what is selected in drop-down or what number is in WEB_EVENTS_PER_PAGE it always reverts to 10 records per page (both Firefox and Chrome). Maybe someone else can spot what is missing in console view.
How 'bout the blank space for the empty "Storage" column?
Fixed in 1.37.39. Thank you!
