Page 1 of 1
Bug: 1.37.37 - No sum in console view of column "month"
Posted: Sun Apr 09, 2023 6:28 am
by bebach8
Zoneminder 1.37.37
Ubuntu 20.04.06 LTS
In a console view there is no sum (number of events or events sizes) of column "Month". It is showing zero. Hour, day and week are working as expected. Please see attached image. Functionality not affected by this. Also Archived column is not shown and zones sum is moved to the left. Thank you for your hard work it is appreciated.
Re: Bug: 1.37.37 - No sum in console view of column "month"
Posted: Mon Apr 10, 2023 9:05 am
by dougmccrary
I'm not seeing that on 1.37.37~20230407133847-
You seem to be missing the archive column, which may be why the zones are to the left.
Posted: Tue Apr 11, 2023 7:07 am
by bebach8
It is same in 20230410154831. Latest Chrome and latest Firefox show same error.
When it is clicked on "zero"
- ZM Bug-02.jpg (31.16 KiB) Viewed 2129 times
this is URL that it goes to
http://xxx.xxx.xxx.xxx/zm/index.php?vie ... limit%5D=0
So, my opinion is that archived column is OK, moved to the left because sum of month column is actually missing.
Posted: Tue Apr 11, 2023 12:26 pm
by iconnor
everything is shifted over, your screenshot doesn't include the whole screen, The missing column is something on the left...
Posted: Wed Apr 12, 2023 6:47 am
by bebach8
Actually sir, you're absolutely right. Everything is shifted to the left. Checked in both latest Firefox and Chrome. Thank you for your hard work.
- ZM Bug3.jpg (68.94 KiB) Viewed 2095 times
Posted: Wed Apr 12, 2023 12:13 pm
by iconnor
So what's missing?!
Posted: Wed Apr 12, 2023 10:08 pm
by dougmccrary
The Month column total events and storage should be >0
I see it too, now.
edit:
Crud. Yeah I was looking at the archived column, which is correctly 0.
Posted: Thu Apr 13, 2023 5:46 am
by bebach8
Nothing is missing, it is just offset to the left. Good eye. Minor nuisance.
Posted: Thu Apr 13, 2023 4:15 pm
by iconnor
There IS something missing, that's why they are shifted! I'd like to figure it out so I can fix it!
Posted: Fri Apr 14, 2023 8:16 am
by bebach8
Can't find what is missing. I don't know if it helps, but I started noticing this shift around same time as paging "problems" occurred.
No mater what is selected in drop-down or what number is in WEB_EVENTS_PER_PAGE it always reverts to 10 records per page (both Firefox and Chrome). Maybe someone else can spot what is missing in console view.
- ZM Bug 4.jpg (131.55 KiB) Viewed 2029 times
- ZM Bug 5.jpg (101.48 KiB) Viewed 2029 times
Posted: Fri Apr 14, 2023 10:26 am
by dougmccrary
How 'bout the blank space for the empty "Storage" column?
Posted: Sun Apr 23, 2023 6:23 am
by bebach8
Fixed in 1.37.39. Thank you!
