Is there a way to test my sw installation without cameras?
michaelbr
Post by michaelbr »
Is there a way to do a dummy test to see if there's a problem with my software installation? It seems to me that it's quite complex, like instead of a camera, use a file as video output of a camera to test the software installation.
Thanks for your comment/suggestion
Michael
Re: Is there a way to test my sw installation without cameras?
Don't have a camera yet?
If you have a "smart" phone, there's apps that will make it an IP camera.
If you get to the welcome page and then the console, it's probably at least mostly right. :?
michaelbr
Post by michaelbr »
dougmccrary wrote: Mon Apr 10, 2023 7:52 am Don't have a camera yet?
Thanks for this tip, which one would you recommend, that works best with ZM?
Michael
You're welcome.
I've not used any of them, so why don't you pick one and if it gives you problems, I'll test it here and let you know if it works, or doesn't?
I have access to several droid and iOS devices.
makers_mark
Post by makers_mark »
michaelbr wrote: Sun Apr 09, 2023 11:14 am Is there a way to do a dummy test to see if there's a problem with my software installation? It seems to me that it's quite complex, like instead of a camera, use a file as video output of a camera to test the software installation.
ffmpeg -re -f lavfi -i testsrc=s=1280x720:r=20 -f rtp_mpegts -pix_fmt yuv420p  rtp://127.0.0.1:4004/
You can run this on the zoneminder server with that localhost:port config, or you can run it on another computer and substitute the IP address accordingly.
On the monitor setup in zoneminder choose source ffmpeg and do everything else like normal (source would be rtp://127.0.0.1:4004 here). This example uses a resolution of 1280x720 and is limited to 20fps (r=20). Take away that '-re' in this instance and ffmpeg will race as fast as allowed.
Check out this page, you can do anything on here (and way more, the skies the limit with ffmpeg) by adapting ffmpeg commands to your need. It's fun to play around with too.
http://trac.ffmpeg.org/wiki/FancyFilteringExamples
michaelbr
Post by michaelbr »
dougmccrary wrote: Mon Apr 10, 2023 10:37 pm You're welcome.
Thanks so much for your help, I'll give it a try, since I'm newbie (lot of reading to do), it might take sometime to post it back.
Michael
michaelbr
Post by michaelbr »
[/quote]
Thanks for this tip, will give it a try.
Michael
