Page 1 of 1
I must be an idiot
Posted: Sat Apr 10, 2004 12:24 am
by zardo
I'm running Fedora Core 1, I installed zm with the following with:
./configure --with-mysql=/usr --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/include/ffmpeg --with-webuser=apache --with-webgroup=apache
No errrors during the install, creating and starting the database. However, there are no files in /var/www/html/zm/ !?? I am missing something totally obvious? I'm assuming that if everything is properly installed, i would start with http://<IP>/zm/ , right ?
thx for any input,
zardo
Re: I must be an idiot
Posted: Sat Apr 10, 2004 12:32 am
by rdmelin
Hi zardo,
Forgive me for asking, but since your post doesn't say so:
Did you run 'make' and as root 'make install' in the zm build directory?
Also I use http://localhost/zm/
Ross
Posted: Sat Apr 10, 2004 3:20 am
by zardo
Hi Ross,
You confirmed that i am an idiot. I had not run "make install" - BTW, the README has only "make", so for the other newbies out there, you need to run "make install" after running "make".
zardo
Posted: Sat Apr 10, 2004 3:56 am
by rdmelin
If you're new to installing from source, and you have ZoneMinder working, give yourself a pat on the back.
It may not be rocket science, but its not point and click either.
Ross
