Playback issues - .sock does not exist
Posted: Tue Apr 18, 2023 4:42 pm
I have quite regularly the problem, that the playback of certain recordings doesn't work. The strange thing is that I cannot see a pattern when this happens and when not.
For example today. I have around 10 recordings from the last 24 hours. But when I start to play one after the other, it happens that one doesn't come up. What I mean is I see the screen with the details like Event-ID, Start-time, End-time etc etc. But the frame with the recoding stays white (empty). The log file shows always two errors:
andSocket /run/zm/zms-469202s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
But I don't understand this message as zms apparently did run and CGI is enabled because otherwise why would it have worked 2 minutes before and maybe 1 or 2 minutes thereafter?getCmdResponse stream error: Socket /run/zm/zms-469202s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. - checkStreamForErrors()
