Broke something after a Python update. Tearing hair out trying to fix.
BaconButty
Post by BaconButty »
Quick version:
I have ES running with YoloV3 for years with no issues. I moved home and broke something, the error was related to one of the scripts pulling an IP from my old address. It wasn't anywhere in the configs, so I assumed a bug and since I could use an update, updated everything anyway.
Worked OK, some faults, decided to update some more. Now I have an error in one of the scripts.
Assumed this was a Python error, and while attempting to reinstall Python, completely killed ubuntu. Had to rebuild most of the system and I'm back at the same error again in "zm_detect.py".
  File "/var/lib/zmeventnotification/bin/zm_detect.py", line 15, in <module>
    import imutils
  File "/usr/local/lib/python3.8/dist-packages/imutils/__init__.py", line 8, in <module>
    from .convenience import translate
  File "/usr/local/lib/python3.8/dist-packages/imutils/convenience.py", line 6, in <module>
    import cv2
  File "/usr/local/lib/python3.8/dist-packages/cv2/__init__.py", line 181, in <module>
    bootstrap()
  File "/usr/local/lib/python3.8/dist-packages/cv2/__init__.py", line 175, in bootstrap
    if __load_extra_py_code_for_module("cv2", submodule, DEBUG):
  File "/usr/local/lib/python3.8/dist-packages/cv2/__init__.py", line 28, in __load_extra_py_code_for_module
    py_module = importlib.import_module(module_name)
  File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "/usr/local/lib/python3.8/dist-packages/cv2/gapi/__init__.py", line 301, in <module>
    cv.gapi.wip.GStreamerPipeline = cv.gapi_wip_gst_GStreamerPipeline
AttributeError: partially initialized module 'cv2' has no attribute 'gapi_wip_gst_GStreamerPipeline' (most likely due to a circular import)
I know this shows CV2 here, however I can change to any other model and get this exact same error.
What am I missing?
Re: Broke something after a Python update. Tearing hair out trying to fix.
Might be your OpenCV version according to Google.
BaconButty
I've seen that myself and tried multiple version with no success. This current install should be using the install.sh version.
I don't know what you mean by that. I donwloaded it and compiled from source as recommended.
BaconButty
Just to be double sure that couldn't be part of it. I went and built from source using: "https://docs.opencv.org/4.x/d7/d9f/tuto ... stall.html"
Still the same.
Which version are you running?
BaconButty
isabell@isabell-MS-7C52:~$ python3
Python 3.8.10 (default, Mar 13 2023, 10:26:41)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cv2.__version__
'4.7.0'
Anything look wrong?
That is functionally ok. I’m on 4.6 and probably a lower Python version too. The OpenCV version is the thing that came up when I Google the error. Might be worth asking on the Slack channel as some of them are using and one is developing the new ZMES.
BaconButty
Can you give me a link or something?
