Bug? Or maybe User Error: Can't create a new user
BigKuma
Post by BigKuma »
This is a fresh install from the master branch in Ubuntu Jammy Server.
1.37.40~20230424175325-jammy amd64
I tried to make a user through the Options->Users-> Add New User
I tried to debug this, installed DBeaver,
Using default zmuser/zmpass credentials only let me see ZM database, not the Users.
This is the error log entry, missing MonitorIds it says:
/26/23, 12:23:11 AM MDT web_php 38693 ERR SQL-ERR '00000', statement was 'INSERT INTO `Users` (`Id`, `Username`, `Name`, `Email`, `Phone`, `Password`, `Language`, `Enabled`, `Stream`, `Events`, `Control`, `Monitors`, `Groups`, `Devices`, `Snapshots`, `System`, `MaxBandwidth`, `MonitorIds`, `TokenMinExpiry`, `APIEnabled`, `HomeView`) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' /usr/share/zoneminder/www/includes/database.php 119
4/26/23, 12:23:11 AM MDT web_php 38693 ERR SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'MonitorIds' in 'field list'', statement was 'INSERT INTO `Users` (`Id`, `Username`, `Name`, `Email`, `Phone`, `Password`, `Language`, `Enabled`, `Stream`, `Events`, `Control`, `Monitors`, `Groups`, `Devices`, `Snapshots`, `System`, `MaxBandwidth`, `MonitorIds`, `TokenMinExpiry`, `APIEnabled`, `HomeView`) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)' params:,MYNAME,MYNAME,,,$MYHASH,,1,View,Edit,Edit,Edit,None,Edit,None,Edit,,,0,1, /usr/share/zoneminder/www/includes/database.php 161
Do I just need to grab a more recent version ?
Or do I need to set other Authentication Options first ?
Thanks!
Re: Bug? Or maybe User Error: Can't create a new user
This looks like the problem -
Sounds like your DB is incomplete.
BigKuma
Post by BigKuma »
Thanks for the reply.
What's the password for the Users DB ?
It’s nothing to do with ZM if you have a ‘users’ DB. ZM users are a table in the ZM DB.
You might just need to update. I think I fixed that on the 23rd.
