I went to update my system today after a few months and I received the following error:
Setting up zoneminder (1.37.40~20230428.25-bullseye) ...
detected systemd
Detected db service is mariadb.service
Checking for db
Db exists.
Updating permissions for user zmuser@localhost
Initiating database upgrade to version 1.37.40 from version 1.37.25
Upgrading database to version 1.37.40
Upgrading DB to 1.37.26 from 1.37.25
Database successfully upgraded to version 1.37.26.
Upgrading DB to 1.37.27 from 1.37.25
Database successfully upgraded to version 1.37.27.
Upgrading DB to 1.37.28 from 1.37.25
ERROR 1050 (42S01) at line 17: Table 'Snapshots_Events' already exists
Output: Checking for Snapshot_Events table
Command 'mysql --defaults-file=/etc/mysql/debian.cnf -hlocalhost zm < /usr/share/zoneminder/db/zm_update-1.37.28.sql' exited with status: 1
Error updating db.
dpkg: error processing package zoneminder (--configure):
installed zoneminder package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
How should I proceed? I do have backups of my db if I need to restore an older db.
Thank you
Upgrading DB to 1.37.28 from 1.37.25 error
Re: Upgrading DB to 1.37.28 from 1.37.25 error
Could be a bug, but I'd try zmupdate.pl manually first-off.
