Zoneminder no longer in EPEL?
BobLaske
Post by BobLaske »
Why was zoneminder removed from EPEL?
Installed: epel-release-9-5.el9.noarch
And, does anyone know of a URL with docs on how to install on Rocky 9.1?
I cannot find anything on the net and this information is wrong;
https://zoneminder.readthedocs.io/en/la ... edhat.html
[root@zmon ~]# sudo dnf config-manager --set-enabled crb
[root@zmon ~]# sudo dnf install zoneminder-httpd
Rocky Linux 9 - BaseOS        5.7 kB/s | 4.1 kB     00:00
Rocky Linux 9 - AppStream        5.7 kB/s | 4.5 kB     00:00
Rocky Linux 9 - CRB        1.4 MB/s | 2.1 MB     00:01
No match for argument: zoneminder-httpd
Error: Unable to find a match: zoneminder-httpd
Re: Zoneminder no longer in EPEL?
Where have you been? ZoneMinder has lived in RPMFusion for the past decade.
Looks like you found the right documentation. It is correct. You just need to follow all of it.
BobLaske
Post by BobLaske »
I did follow 'all' of it and shared what was happening.
Anyhow, I re-installed ubuntu and got it up and running.
BobLaske wrote: Tue May 16, 2023 2:01 pm I did follow 'all' of it and shared what was happening.
Negative. You skipped the first sentence, which describes how to enable RPMFusion.
https://zoneminder.readthedocs.io/en/la ... zoneminder
BobLaske
Post by BobLaske »
Yup, you're right. I read that but didn't think it was anything I had to do so moved on.
Maybe I'll re-install but it's working fine now. Thanks for the input.
