Control script for Alptop AT-200DW
therps2
Post by therps2 »
I've created a control script for the Alptop AT-200DW outdoor hardwired LAN/wireless PTZ camera.
It seems to work, as far as pan and tilt is concerned. I can't seem to get the zoom or focus stuff working yet, but I'm still working on it. The camera uses an HI3510 chipset, but Alptop doesn't provide any documentation regarding how it's used. This script is based on a lot of testing and playing around. It does have provisions for all of the main functions provided in the Zoneminder control interface, but I can only swear to the pan/tilt mechanisms at this time.
The camera provides video at "rtsp://ipaddr:554/11" (high resolution) and "rtsp://ipaddr:554/12" (low resolution).
However, in case someone needs to get up and running, I'm attaching my script.
# ZoneMinder Alptop AT-200DW Protocol Module
# Copyright (c) 2023,  Richard P. Stevens, II ("rps2" in the comments)
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
# This module contains the implementation of the Alptop AT-200DW device
# control protocol
package ZoneMinder::Control::AlptopAT200DW;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Control;
our %CamParams = ();
# Alptop AT-200DW Control Protocol
# In the "Control Address" field of the Control section for the camera,
# use the format:
#	USERNAME:PASSWORD@ADDRESS:PORT
# For example:
#	admin:admin@192.168.1.1:80
# As shipped, the administrator account for the camera is:
#	Username: "admin" (no quotes, all lower case)
#	Password: "admin" (no quotes, all lower case)
# Also, note that, by default, the video is available at
#	rtsp://192.168.1.41:554/11 (main, high-res video feed)
#	rtsp://192.168.1.41:554/12 (secondary low-res video feed)
use Time::HiRes qw( usleep );
# NOTE: These cameras have speeds associated with their pan and tilt
# movements. These values can be between 0 and 63. We're going to choose a
# medium # value of 32 (half speed). I've found that the cameras slew REALLY
# fast, so adjust this "$camMoveSpeed" value if you want to speed it up or
# slow it down (0 = slow, 63 = fast)
our $camMoveSpeed = 32;
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
#    Info( "http://".$self->{Monitor}->{ControlAddress}."/$cmd".$self->{Monitor}->{ControlDevice} );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub getCamParams
    my $self = shift;
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=getimageattr";
    my $req = $self->sendCmd( $cmd );
        # Parse results setting values in %FCParams
        my $content = $res->decoded_content;
        while ($content =~ s/var\s+([^=]+)=([^;]+);//ms) {
            $CamParams{$1} = $2;
    else
# Auto Stop
# This makes use of the ZoneMinder Auto Stop Timeout on the Control Tab
sub autoStop
    my $self = shift;
    my $delay = shift;
    # Wait "$delay" microseconds and stop the camera movement...
    Debug( "Auto Stop" );
    usleep( $delay );
    my $cmd = "/cgi-bin/hi3510/ptzctrl.cgi?-act=stop";
# Reset the Camera
sub reset
    my $self = shift;
    Debug( "Camera Reset" );
    # Move to default position
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-act=home";
    # Reset all other values to default
    # ### NEEDS WORK! (RPS2) ####
    # I'd suggest using a "reboot camera" rather than a full-on reset.
    # It'd be dangerous to do a reset, so this code is commented out.
    # $cmd = "cgi-bin/hi3510/param.cgi?cmd=setimageattr&-image_type=1&-default=on";
    #$self->sendCmd( $cmd );
# Reboot Camera (on Sleep button)
sub sleep
    my $self = shift;
    Debug( "Camera Reboot" );
    my $cmd = "cgi-bin/hi3510/sysreboot.cgi";
# Stop the Camera
sub moveStop
    my $self = shift;
    Debug( "Camera Stop" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-act=stop";
# Up Arrow
sub moveConUp
    my $self = shift;
    Debug( "Move Up" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=up&-speed=".$camMoveSpeed;
    $self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
# Down Arrow
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=down&-speed=".$camMoveSpeed;
# Left Arrow
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=left&-speed=".$camMoveSpeed;
# Right Arrow
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=right&-speed=".$camMoveSpeed;
# Zooming. The API for the hi3510 chipset says it can zoom, but I can't
# seem to make it work (nor does the web interface for the camera) so it
# MAY not work. I'll leave this code in place, just the same.
# Zoom In (NOTE: We use the self-stop feature of the camera to stop zoom)
sub zoomConTele
    my $self = shift;
    Debug( "Zoom Tele" );
    # Not sure if it's "zoom in" or "zoomin". We'll try "zoomin"
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=1&-act=zoomin&-speed=".$camMoveSpeed;
# Zoom Out (NOTE: We use the self-stop feature of the camera to stop zoom)
sub zoomConWide
    my $self = shift;
    Debug( "Zoom Wide" );
    # Not sure if it's "zoom out" or "zoomout". We'll try "zoomout"
    my $cmd = "cgi-bin/hi3510/ptzctrl.cgi?-step=1&-act=zoomout&-speed=".$camMoveSpeed;
# These cameras don't not have built-in diagonal commands, so we emulate them
# Diagonally Up Right Arrow
sub moveConUpRight
    my $self = shift;
# Diagonally Down Right Arrow
sub moveConDownRight
    my $self = shift;
# Diagonally Up Left Arrow
sub moveConUpLeft
    my $self = shift;
# Diagonally Down Left Arrow
sub moveConDownLeft
    my $self = shift;
# NOTE: I'm not sure how many presets these cameras support. I chose 8.
# Seems reasonable.
# Set Camera Preset
sub presetSet
    my $self = shift;
    my $params = shift;
    if (( $preset >= 1 ) && ( $preset <= 8 )) {
        my $cmd = "cgi-bin/hi3510/preset.cgi?-act=set&-status=1&-number=".$preset;
# Recall Camera Preset
sub presetGoto
    my $self = shift;
    my $params = shift;
        my $cmd = "cgi-bin/hi3510/preset.cgi?-act=goto&-number=".$preset;
    if ( $preset == 9 ) {
        $self->horizontalPatrol();
    if ( $preset == 10 ) {
        $self->verticalPatrol();
# Do horizontal or vertical scanning.
# Horizontal Patrol
sub horizontalPatrol
    my $self = shift;
    Debug( "Horizontal Patrol" );
    my $cmd = "cgi-bin/hi3510/cmd=ptzctrl.cgi?-step=0&-act=hscan&-speed=".$camMoveSpeed;
# Vertical Patrol
sub verticalPatrol
    my $self = shift;
    Debug( "Vertical Patrol" );
    my $cmd = "cgi-bin/hi3510/cmd=ptzctrl.cgi?-step=0&-act=vscan&-speed=".$camMoveSpeed;
# NOTE: These cameras use brightness values of 0-255.
# Increase Brightness
sub irisAbsOpen
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'brightness'});
    my $step = $self->getParam( $params, 'step' );
    $CamParams{'brightness'} += $step;
    $CamParams{'brightness'} = 255 if ($CamParams{'brightness'} > 255);
    Debug( "Increase Brightness" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setimageattr&-brightness=".$CamParams{'brightness'};
# Decrease Brightness
sub irisAbsClose
    my $self = shift;
    my $params = shift;
    $CamParams{'brightness'} -= $step;
    $CamParams{'brightness'} = 0 if ($CamParams{'brightness'} < 0);
    Debug( "Decrease Brightness" );
# NOTE: These cameras use contrast values of 0-255.
# Increase Contrast
sub whiteAbsIn
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'contrast'});
    $CamParams{'contrast'} += $step;
    $CamParams{'contrast'} = 255 if ($CamParams{'contrast'} > 255);
    Debug( "Increase Contrast" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setimageattr&-contrast=".$CamParams{'contrast'};
# Decrease Contrast
sub whiteAbsOut
    my $self = shift;
    my $params = shift;
    $CamParams{'contrast'} -= $step;
    $CamParams{'contrast'} = 0 if ($CamParams{'contrast'} < 0);
    Debug( "Decrease Contrast" );
# NOTE: These cameras use saturation values of 0-255.
# Increase Saturation
sub satIncrease
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'saturation'});
    $CamParams{'saturation'} += $step;
    $CamParams{'saturation'} = 255 if ($CamParams{'saturation'} > 255);
    Debug( "Increase Saturation" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setimageattr&-saturation=".$CamParams{'saturation'};
# Decrease Saturation
sub satDecrease
    my $self = shift;
    my $params = shift;
    $CamParams{'saturation'} -= $step;
    $CamParams{'saturation'} = 0 if ($CamParams{'saturation'} < 0);
    Debug( "Decrease Saturation" );
# NOTE: These cameras use sharpness values of 0-255.
# Increase Sharpness
sub sharpIncrease
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'sharpness'});
    $CamParams{'sharpness'} += $step;
    $CamParams{'sharpness'} = 255 if ($CamParams{'sharpness'} > 255);
    Debug( "Increase Sharpness" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setimageattr&-sharpness=".$CamParams{'sharpness'};
# Decrease Sharpness
sub sharpDecrease
    my $self = shift;
    my $params = shift;
    $CamParams{'sharpness'} -= $step;
    $CamParams{'sharpness'} = 0 if ($CamParams{'sharpness'} < 0);
    Debug( "Decrease Sharpness" );
# NOTE: These cameras use hue values of 0-127.
# Increase Hue
sub hueIncrease
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'hue'});
    $CamParams{'hue'} += $step;
    $CamParams{'hue'} = 127 if ($CamParams{'hue'} > 127);
    Debug( "Increase Hue" );
    my $cmd = "cgi-bin/hi3510/param.cgi?cmd=setimageattr&-hue=".$CamParams{'hue'};
# Decrease Hue
sub hueDecrease
    my $self = shift;
    my $params = shift;
    $CamParams{'hue'} -= $step;
    $CamParams{'hue'} = 0 if ($CamParams{'hue'} < 0);
    Debug( "Decrease Hue" );
1;
