SQLSTATE[HY000] [1698] Access denied for user 'zmuser'@'localhost' [SOLVED]
michaelbr
Post by michaelbr »
My PC crashed yesterday, installed before crash ZM 1.36.X without problem, but this time got an error when trying to restart mysql service
sudo service mysql restart
(with error "mysql: unrecognized service"), after changing
/etc/mysql/mariadb.conf.d/50-server.cnf
file, could connect to mariadb using
mysql -uroot -p
, mysql is not in init.d, but mariadb is, so instead restarted mariadb using
sudo service mariadb restart
. Then installed ZM using
zm-install
script, when tried to run ZM, got the following error:
Unable to connect to ZM db using dsn mysql:host=localhost;dbname=zm;charset=utf8
What I'm doing wrong? Is it because of the mysql service can't restart or some other reason? How can I solve this problem?
OS: MX Linux 21.3 (Debian 11 based)
Thanks for your comment/suggestion
Michael
Re: SQLSTATE[HY000] [1698] Access denied for user 'zmuser'@'localhost'
Sounds like DB is running. Cannot auth as ZM user/pass.
michaelbr
Post by michaelbr »
Magic919 wrote: Sat May 27, 2023 3:52 pm Sounds like DB is running. Cannot auth as ZM user/pass.
That's the problem, I can't find the db named zm and user named zmuser, does ZM requires both MySQL AND MariaDB to work, or either one of them is enough? If zm and zmuser is in MySQL, what MariaDB is doing there? Can I install MySQL before installing ZM? will ZM wipe out MySQL installation?
Michael
You can use EITHER MySQL or MariaDB. I use MariaDB with ZM. It’s thought to perform a bit better. Some of the MySQL commands work with MariaDB as they are very similar. It’s basically a drop in replacement.
michaelbr
Post by michaelbr »
Magic919 wrote: Sun May 28, 2023 3:14 pm You can use EITHER MySQL or MariaDB. I use MariaDB with ZM. It’s thought to perform a bit better. Some of the MySQL commands work with MariaDB as they are very similar. It’s basically a drop in replacement.
Thanks for your reply, it seems that I need to create zmuser & zm DB manually, for zmuser, do I need password for this user when creating? If so where in ZM I have to write this password (which configuration file so that ZM can connect it to zm DB?)
Michael
michaelbr
Re: SQLSTATE[HY000] [1698] Access denied for user 'zmuser'@'localhost' [SOLVED]
Post by michaelbr »
Followed this post and it solved my problem to install ZM on MX Linux.
Michael
