Akuvox R20A doesn't work...
GbMax78
Post by GbMax78 »
Hi guys,
I have seven Akuvox R20A which I can see by VLC with rtsp without problems (audio and video are perfect!); this is the configuration page: https://ibb.co/sWkf7r5
I installed Zone Minder on Debian Bookworm from repositories, here below the screenshots:
https://ibb.co/jGwCYy0
https://ibb.co/6nZvWWr
https://ibb.co/HNpdjZt
https://ibb.co/0Dbwk9W
I didn't understand why I can see nothing... :\
GabrieleMax
Re: Akuvox R20A doesn't work...
I'd expect it to log something.
Did you use the same url in vlc as in the monitor settings? Cuz I so no path or user auth...
It may be that the camera only supports either UDP or TCP, so try both.
I see that your logs button is RED, so it seems like it IS logging something.
GbMax78
Re: Akuvox R20A doesn't work in realtime view
Post by GbMax78 »
I solved the issue about the configuration and now ZM is connected to the device:
https://ibb.co/StLVYZq
https://ibb.co/Jn9WXB0
https://ibb.co/QJ2W1K4
I inserted in the rtsp link the username and password but now I had another problem, I can't see the realtime view.
https://ibb.co/N1Tv1dT
I tried also with different web browsers like Chrome, Firefox, Edge, etc. but I understood it's not a browser problem, obviously I tried to search on internet and it seems it's an API issue but I don't know what should I do now, I'm using ZM on Debian Bookworm.
Regards.
GabrieleMax
GbMax78
Post by GbMax78 »
Thanks to a member of ZoneMinder's crew I found the first solution so... I configured CGI (I followed this guide: https://www.ionos.com/digitalguide/serv ... on-apache/ it works also on my Debian Bullseye.
Now I have this issue:
https://ibb.co/ZLcbpwM
Logs said:
https://ibb.co/m5fk5Ms
The ip cam config on ZM is:
https://ibb.co/MkQpMTz
https://ibb.co/TqQ5XBL
https://ibb.co/3C44Nc6
This is the Akuvox config:
https://ibb.co/hDc44GG
https://ibb.co/WD4cRWr
I tried to find how to fix the error showed on the Log's page but I didn't find a real solution... :roll:
Regards.
GbMax78
That error generally means that the capture process isn't running.
GbMax78
Post by GbMax78 »
iconnor wrote: Sat Aug 19, 2023 1:22 pm That error generally means that the capture process isn't running.
Thanks for your reply, I edited this file: /etc/zm/conf.d/01-system-paths.conf
# Full Path to ZoneMinder's mapped memory files
# The web account user must have full read/write permission to this folder.
ZM_PATH_MAP=/dev/shm
# Full Path to ZoneMinder's socket folder
ZM_PATH_SOCKS=/run/zm
# Full path to ZoneMinder's log folder
ZM_PATH_LOGS=/var/log/zm
# Full path to ZoneMinder's swap folder
ZM_PATH_SWAP=/tmp/zm
Now I have just one web account on zm db and it is "admin" and obviously it is not a Linux user so should I create a Linux user named "admin" to give it permissions to the above directories and should I do it for every new zm users?
Regards.
GbMax78
A normal web account user would be www-data or apache. It's a system (Linux) account that runs the webserver. Nothing to do with ZM users.
GbMax78
Post by GbMax78 »
Magic919 wrote: Mon Aug 21, 2023 7:43 am A normal web account user would be www-data or apache. It's a system (Linux) account that runs the webserver. Nothing to do with ZM users.
Ok, thanks to clarify it to me; I gived to the directories written in my last post, to do a test, +777 permissions but nothing happened :\
After I unchecked "OPT_USE_AUTH" I tried to understand by http://server_ip/zm/api/host/getVersion.json if json works but I have a 404 not found.
I also checked /dev/shm/zm.mmap.1 and there aren't files so there isn't zm.mmap.1
Regards.
GbMax78
I'm not clear what you are trying to achieve.
Isaac is saying the capture process is not running. These things don't happen in silence, so I'd be guided by what appears in the logs. Turn up logging if you have to.
