bbawkon
Posts: 5 Joined: Tue Jun 06, 2023 2:32 am
Post
by bbawkon » Tue Jun 06, 2023 2:36 am
Hello everyone,
Running 1.36.33 on Ubuntu 22.04
Most everything is working properly, but a few things yield an HTTP 500 Error. Looking at event frames, for instance, is one such thing.
visiting
http://zoneminder/zm/index.php?view=frame&eid=458&fid=380
gives HTTP ERROR 500.
Apache error.log stores:
[Mon Jun 05 22:35:01.586436 2023] [php:error] [pid 12856] [client 192.168.101.14:64203] PHP Fatal error: Uncaught ValueError:
imagecreatetruecolor(): Argument #1 ($width) must be greater than 0 in /usr/share/zoneminder/www/includes/Event.php:473\nStack
trace:\n#0 /usr/share/zoneminder/www/includes/Event.php(473): imagecreatetruecolor()\n#1
/usr/share/zoneminder/www/skins/classic/views/frame.php(63): ZM\\Event->getImageSrc()\n#2
/usr/share/zoneminder/www/index.php(282): require_once('...')\n#3
{main}\n thrown in /usr/share/zoneminder/www/includes/Event.php on line 473,
referer: http://zoneminder/zm/index.php?view=frames&eid=458
Any thoughts? Google was no help, unfortunately.
bbawkon
Post
by bbawkon » Tue Jun 06, 2023 2:42 am
"View Matches" of a Filter also throws HTTP Error 500.
http://zoneminder/zm/index.php?view=montagereview&action=&object=filter&filter%5BName%5D=PurgeWhenFull&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bobr%5D=0&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=Archived&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=0&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bcbr%5D=0&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bobr%5D=0&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Battr%5D=DiskPercent&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bval%5D=80&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcbr%5D=0&filter%5BQuery%5D%5Bterms%5D%5B2%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B2%5D%5Bobr%5D=0&filter%5BQuery%5D%5Bterms%5D%5B2%5D%5Battr%5D=EndDateTime&filter%5BQuery%5D%5Bterms%5D%5B2%5D%5Bop%5D=IS%20NOT&filter%5BQuery%5D%5Bterms%5D%5B2%5D%5Bval%5D=NULL&filter%5BQuery%5D%5Bterms%5D%5B2%5D%5Bcbr%5D=0&filter%5BQuery%5D%5Bsort_field%5D=Id&filter%5BQuery%5D%5Bsort_asc%5D=1&filter%5BQuery%5D%5Blimit%5D=100&filter%5BAutoExecuteCmd%5D=&filter%5BAutoDelete%5D=1&filter%5BAutoCopyTo%5D=&filter%5BAutoMoveTo%5D=&filter%5BBackground%5D=1&filter%5BEmailTo%5D=&filter%5BEmailSubject%5D=&filter%5BEmailBody%5D=
With apache error.log of:
[Mon Jun 05 22:40:18.686450 2023] [php:warn] [pid 12831] [client 192.168.101.14:64539] PHP Warning:
Undefined array key "attr" in /usr/share/zoneminder/www/skins/classic/views/
montagereview.php on line 105, referer: http://zoneminder/zm/index.php?view=filter&Id=1
[Mon Jun 05 22:40:18.686568 2023] [php:error] [pid 12831] [client 192.168.101.14:64539] PHP Fatal error:
Uncaught TypeError: Cannot access offset of type string on string in
/usr/share/zoneminder/www/skins/classic/views/montagereview.php:105\nStack trace:\n#0
/usr/share/zoneminder/www/index.php(282): require_once()\n#1
{main}\n thrown in /usr/share/zoneminder/www/skins/classic/views/montagereview.php on line 105,
bbawkon
Post
by bbawkon » Fri Jun 16, 2023 10:46 am
Did a little more investigation.
When viewing frames, the HTTP 500 and associated errors are only produced if WEB_x_SCALE_THUMBS is enabled. Turning that option off solves the issue.
I added a little debug code to Event.php, and with WEB_x_SCALE_THUMBS available, $fraction (around line 449) is 0.00 before being passed to imagecreatetruecolor()
Any thoughts on what could cause that?
I'm still working backward, but I'm hopeful someone who knows more about ZM code than I do has an idea.
Using Medium B/W as an example,
WEB_M_DEFAULT SCALE = 50
WEB_M_SCALE_THUMBS = YES
WEB_RESIZE_CONSOLE = YES
WEB_LIST_THUMB_WIDTH = 48
WEB_LIST_THUMB_HEIGHT = 0
WEB_LIST_THUMBS = YES
WEB_ANIMATE_THUMBS = YES
Thanks,
Ben
