Montage page super-slow with setting "Keyframes Only + On Demand"
Posted: Sun Jun 18, 2023 8:25 am
As i'm struggeling with high CPU usage fur just a few cams, there someone mentioned it's not that much of a problem in version 1.37, as there is a new option "Keyframes Only and On Demand" and it's true.
My load goes down from like 30% to just 1-2% per cam. Nice!
But there seems to be another big problem with this:
But setting this option and open up montage view, the page seems to crash, but indeed it's just super slow.
It is showing the first view of every cam on calling, but then it seems to never finish loading (you see firefox is trying to load the site) and one by one the images disappear. While this you can try to point at the "console" tab on top. It takes like 1-2 minutes(!) until the point is highlighted. And after clicking it another 2-3 minutes to open the page. As soon as you leave the montage view, everything seems to work fine again.
The most curious thing about that is, that there is no suspicious load on the host system!
The load for the cam processes goes up to 30% again (which is like fine, cause i call for every cams view), but there is nothing markable else, like high load on apache process or such...
Also this problem does not occur when viewing the cams one by one.
