Unable to create source for /zoneminder/run/video_fifo_1.none zm_rtsp_server.cpp
Posted: Fri Jun 23, 2023 1:22 pm
Hello
I'm running ZoneMinder 1.36.33 in the https://github.com/zoneminder-container ... inder-base container. I have four analog cameras connected to a bt878 video card and using Video4Linux2. I have configured them as Local cameras i ZoneMinder. All work great, no errors.
Now I want to re-stream them to my HomeAssistant server. I set ZoneMinder Options -> Network -> MIN_RTSP_PORT = 2000 and restart and I can see that ZoneMinder listens to port 2000. I then modify settings for one of the cameras and set Misc -> RTSPServer enabled and RTSPStreamName to entre.
When I save this ZoneMinder gets an error:
zm_rtsp_server 561 ERR Unable to create source for /zoneminder/run/video_fifo_1.none zm_rtsp_server.cpp 282
zm_rtsp_server 561 WAR Unknown format in /zoneminder/run/video_fifo_1.none zm_rtsp_server.cpp 279
I can not access the stream from VLC; rtsp://192.168.1.10:2000/entre should work but it doesn't. I have tried restarting/rebooting, but no success.
Logging into the container to check the file. It is being created as following:
prw------- 1 www-data www-data 0 Jun 23 12:09 video_fifo_1.none
Anyone has any ideas on what's wrong? In some other post discussing RTSP and audio I saw another user who had the file created as video_fifo_1.h264. Is the problem that zm_rtsp_server doesn't understand what type the camera is? Should not not say video_fifo_1.none but something else?
Any ideas?
Any ideas?
