Hello!
When i enter Montage tab, my Zoneminder freezes and i can't use another tabs (hangs in loading).
Montage - Zoneminder freezes
Re: Montage - Zoneminder freezes
How many cams at what resolution/framerate?
Is it the browser or ZM that hangs?
Version 1.37.41.
8 cams 720p.
Added memory, but the result is the same.
8 cams 720p.
Is it the browser or ZM freezing?
Are you using multi-port? You need that for most browsers to show more than 6 cameras, unless you tweak the browser.
