Hi all,
I have zoneminder with the 1.36.33 version on my debian bookworm.
I want to enable or disable camera and the function choosed (monitor, ...).
What's the binary which is able to do this ?
zmc, zma, zms or zmu ? Or a *.pl file ?
I have seen this doc but it's too big for me
https://zoneminder.readthedocs.io/en/st ... m-overview
Thanks a lot and have a nice day.
Activate Camera Function with a binary
Re: Activate Camera Function with a binary
The API is the best way to control Zoneminder.
https://zoneminder.readthedocs.io/en/stable/api.html
There are lots of examples and the doc explains how to get a key and how to pass it to Zoneminder and ask it to do things. Then you can write simple scripts to perform jobs safely.
Ok thank you, i will try this.
