v1.37.43 issues
JBE-Zorg
v1.37.43 issues
Post by JBE-Zorg »
Just updated to 1.37.43 (zoneminder:amd64 (1.37.43~20230825124927-jammy) and cameras stopped working/recording. Looks like ZoneMinder will try to connect to the cameras and maybe get an image or two then stop. Everything was working normally prior to the update (1.37.42~20230810110346-jammy).
ZoneMinder console shows:
2023-09-10 10_43_46-ZM - Console.png (19.68 KiB) Viewed 13866 times
I cleared out all of my events prior to upgrading, which is why there's none shown.
The Log is showing that it's killing zmc constantly, see the following snippet. This is repeated over and over:
2023-09-10 10_35_25-ZM - System Log.png (64.38 KiB) Viewed 13866 times
Monitoring the processes, zmc appears to start, jump to near full cpu usage and then gets killed about a minute after starting:
gyzod
Re: v1.37.43 issues
Post by gyzod »
Same here, with yesterday's build.
tyronesluck
Re: v1.37.43 issues
Post by tyronesluck »
I had the same issue, with the update from 9th September.
I found that if I disable the recording of audio with the "Whether to store the audio stream when saving an event." check box then my cpu load goes back to normal and it records and I can preview the live feeds again.
I noticed the latest version has something in it to do with audio streams with ffmpeg, perhaps its something to do with that?
JBE-Zorg
Re: v1.37.43 issues
Post by JBE-Zorg »
tyronesluck wrote: Mon Sep 11, 2023 5:19 pm I found that if I disable the recording of audio with the "Whether to store the audio stream when saving an event." check box then my cpu load goes back to normal and it records and I can preview the live feeds again.
Thank you and good catch! Turning off the "Whether to store the audio stream when saving an event." on all my cameras allowed normal recording and playback to work as expected (without audio of course).
JBE-Zorg
Re: v1.37.43 issues
Post by JBE-Zorg »
Quick update. There was a new build available (1.37.43~20230911114421-jammy), after installation I can enable recording audio again and things seem to be working smoothly (so far).
borozenetsww
Re: v1.37.43 issues
Post by borozenetsww »
Any events (hour, day, etc...) not show now.
"Loading, please wait"
[Tue Sep 12 08:51:44.094169 2023] [php:error] [pid 2556419] [client 10.8.0.2:57931] PHP Fatal error: Uncaught Error: Call to undefined function int() in /usr/share/zoneminder/www/ajax/events.php:207\nStack trace:\n#0 /usr/share/zoneminder/www/ajax/events.php(121): queryReq
uest()\n#1 /usr/share/zoneminder/www/index.php(260): require_once('...')\n#2 {main}\n thrown in /usr/share/zoneminder/www/ajax/events.php on line 207, referer: http://192.168.3.3/zm/index.php?view=ev ... ateTime&fi
lter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+hour&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Battr%5D=Monitor&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bt
erms%5D%5B1%5D%5Bval%5D=1&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&filter%5BQuery%5D%5Bskip_locked%5D=&filter%5BQuery%5D%5Blimit%5D=0
borozenetsww
Re: v1.37.43 issues
Replacing back from diff in file /web/ajax/events.php. Work correct.
- if ($filter->limit() and !count($filter->post_sql_conditions())) {
+ if (int($filter->limit()) and !count($filter->post_sql_conditions())) {
Re: v1.37.43 issues
Looks like the ubuntu repo is somehow fixed now. (jammy, anyway)
tyronesluck
Re: v1.37.43 issues
borozenetsww wrote: Tue Sep 12, 2023 4:19 am Replacing back from diff in file /web/ajax/events.php. Work correct.
Can confirm I had this same problem too, and this also fixed it.
tyronesluck
Re: v1.37.43 issues
JBE-Zorg wrote: Mon Sep 11, 2023 10:31 pm Quick update. There was a new build available (1.37.43~20230911114421-jammy), after installation I can enable recording audio again and things seem to be working smoothly (so far).
Is it recording audio for you since this update? I just updated mine to the same version, and enabled recording audio, but dont seem to have any audio. Using mediainfo the mp4 file doesn't have an audio track.
JBE-Zorg
Re: v1.37.43 issues
Post by JBE-Zorg »
tyronesluck wrote: Tue Sep 12, 2023 8:44 am
After doing the ajax fix above, I downloaded an event and you are correct - no audio track available.
borozenetsww
Re: v1.37.43 issues
Last build zoneminder-1.37.43~20230912090755 corrects Ajax problem.
Thanks to Iconnor.
Re: v1.37.43 issues
Sorry for the sloppy commits.
Now about this audio, can we confirm that it stopped working?
tyronesluck
Re: v1.37.43 issues
Yep, its not recording the audio on my camera anymore. It used to before the recent updates.
Using mediainfo, it shows just the Video stream.
Re: v1.37.43 issues
Today's latest build should fix the audio recording.
