Enable/disable monitor via script
fluffykeith
Post by fluffykeith »
Hi
doc says "...camera to be enabled or disabled by external triggers or scripts."
I have seen mention of x10 enabling monitors. Is this the only way or is there some way I can enable/disable monitors using Python?
When I say enable disable I really mean enable/disable motion detection as I still want the monitor working as just a monitor.
thanks
Keith
geraldbrandt
Re: Enable/disable monitor via script
Post by geraldbrandt »
I have a single line in my crontab:
# Start monitoring on Monitor 3
0 22 * * * root /usr/bin/curl -XPOST http://localhost/zm/api/monitors/3.json -d "Monitor[Function]=Modect&Monitor[Enabled]=1"
# Stop monmitoring on monitor 3
0 6 * * * root /usr/bin/curl -XPOST http://localhost/zm/api/monitors/3.json -d "Monitor[Function]=Monitor&Monitor[Enabled]=1"
fluffykeith
That's great, Thank you.
I guess that html post is what happens when we change the settings on the monitor settings pages. So the same mechanism could be used to change anything?
There are docs for the API if you want to dig in https://zoneminder.readthedocs.io/en/stable/api.html
geraldbrandt
fluffykeith wrote: Fri Sep 15, 2023 9:39 pm That's great, Thank you.
Those lines use the Zoneminder API.
