do_debian_package.sh fails for 1.37.44
pygr
Post by pygr »
A build + install of a version 1.37.42 deb on my system (Odroid N2+ with Dietpi bookworm) succeeds. The service mostly works as expected except that the 3 running zmc processes slowly (hours) increase their memory usage, so that eventually the oom killer has to do its job to restart zoneminder.
So I figured I'd try to clone and build 1.37.44 to see if the problem had been fixed. Using the same procedure that successfully builds 1.37.42 doesn't work for 1.37.44.
Any ideas how to get it to succeed?
For 1.37.44, the execution of
~/ZM/utils/do_debian_package.sh --snapshot=NOW --fork=myfork --branch=mybranch --type=local
ends with
gmake[2]: Leaving directory '/home/droid/ZM/utils/zoneminder_1.37.44~20230920121944.orig/dbuild/CMakeFiles/CMakeScratch/TryCompile-9S1b8t'
Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)":
cc (Debian 12.2.0-14) 12.2.0
Copyright (C) 2022 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
dh_auto_configure: error: cd dbuild && cmake -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_BUILD_TYPE=None -DCMAKE_INSTALL_SYSCONFDIR=/etc -DCMAKE_INSTALL_LOCALSTATEDIR=/var -DCMAKE_EXPORT_NO_PACKAGE_REGISTRY=ON -DCMAKE_FIND_USE_PACKAGE_REGISTRY=OFF -DCMAKE_FIND_PACKAGE_NO_PACKAGE_REGISTRY=ON -DFETCHCONTENT_FULLY_DISCONNECTED=ON -DCMAKE_INSTALL_RUNSTATEDIR=/run "-GUnix Makefiles" -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_INSTALL_LIBDIR=lib/aarch64-linux-gnu -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_BUILD_TYPE=Release -DBUILD_MAN=0 -DZM_NO_PCRE=ON -DZM_CONFIG_DIR=/etc/zm -DZM_CONFIG_SUBDIR=/etc/zm/conf.d -DZM_RUNDIR=/run/zm -DZM_SOCKDIR=/run/zm -DZM_TMPDIR=/var/tmp/zm -DZM_CGIDIR=/usr/lib/zoneminder/cgi-bin -DZM_CACHEDIR=/var/cache/zoneminder/cache -DZM_DIR_EVENTS=/var/cache/zoneminder/events -DZM_PATH_SHUTDOWN=/sbin/shutdown -DZM_PATH_ZMS=/zm/cgi-bin/nph-zms .. returned exit code 1
make[1]: *** [debian/rules:18: override_dh_auto_configure] Error 2
make[1]: Leaving directory '/home/droid/ZM/utils/zoneminder_1.37.44~20230920121944.orig'
make: *** [debian/rules:14: build] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
debuild: fatal error at line 1182:
dpkg-buildpackage -us -uc -ui -i -b failed
Error status code is: 0
Build failed.
pygr
Re: do_debian_package.sh fails for 1.37.44
Post by pygr »
do_debian_package.sh succeeds for 1.37.45!
